Welcome to Club SAITO !
Old 05-26-2014, 06:51 PM
  #26576
blw
blw's Avatar
Originally Posted by jeffie8696
Lets see, the 1.00 will make my 1,2,3,,, 5th Saito now. Cool.
I recently picked up some(like 6 gallons LOL) 15% Heli synthetic with 23% oil I will have to try that this summer..
Oh, that's you. Not my fault since I'm used to the old pic of you in the helmet liner. But I didn't know you had Saitos either.
Sounds like a good catch on the fuel. I don 't mind some extra oil either.
Never had much luck with MA props so far. APCs always seem to git it done.
Old 05-26-2014, 07:09 PM
  #26577
jeffie8696
jeffie8696's Avatar
The heli fuel I picked up was actually for winter use in my engines. it has a low viscosity lube. It works great in the snow, and I just ran a gallon of it through an OS46LA (worse case scenario LOL) which I inspected afterwards and found no ill effects whatsoever. I use it in both my 46LA and my 65LA with great results , the 46 would rattle at low speed (typical bushing rattle) more than the 65 which I attribute to resonance.
Old 05-26-2014, 10:24 PM
  #26578
Rudolph Hart
Rudolph Hart's Avatar
Well you can count so that can't be too bad..tune your own engines
Old 05-27-2014, 02:56 AM
  #26579
SrTelemaster150
SrTelemaster150's Avatar
Originally Posted by charlie1960
Heavy prop, say a 14x8 MA. I think its called a Classic, it has almost square tips.
And it will be sharp enough to shave with right out of that package.
A lot of guys don't like a MA, but its a great prop on the 1.00.
A heavy prop smooths out the pulses at idle and lets you screw the idle down a bit.
It will run great on 10% fuel. 18 to 20% lube is good.
As long as you get oil out that bypass tube, its all good.
But that low speed needle is very important. They aint bull****tin' ya there.
oh by the way....I wouldn't part with my 1.00
The MAS "Classic" series has round tips like a typical WW-II fighter propeller. The instructions that accompany the MAS "Classic" propellers advise one to scrape the edges of the propeller to remove the sharp mold flashing.
Old 05-27-2014, 04:10 AM
  #26580
Rudolph Hart
Hi guys just back in from the shed.Spent last week and the weekend putting together a 46 size deccy to replace the one i crashed last year.I like flying them with the 82 it's nice power and handling combination.This time the 82 is nearly inverted instead of side mount so will see what tuning things happen.I run 10% but if it flies good would like to increase that and see what happens.
Old 05-27-2014, 07:09 AM
  #26581
blw
blw's Avatar
APC props need the flashing on the leading edges sanded down with fine grit.
Old 05-27-2014, 07:15 AM
  #26582
blw
blw's Avatar
Originally Posted by FNQFLYER
We left that site soon after because the workers on the site got sick of us landing and take models off on the corrogated roof of their dongas. It was a good place while it lasted
You would fit right in with some of the members of the club here. I joined in 2004 and am always hearing stories. However, I'll always think about corrugated roofs as rumble strips now.
Old 05-27-2014, 02:45 PM
  #26583
charlie1960
K series Master Airscrew.
White tips
Old 05-27-2014, 03:09 PM
  #26584
Capt Lou
I'm planning to build a Great Planes Giant Decathlon. I can put a Saito 150 in it but I don't have any experience with the motor. I have several FA.91's and 1.00' and think they are great. Can anyone tell me about the FA-150? Thank you in advance.
Capt Lou
Old 05-27-2014, 03:15 PM
  #26585
FNQFLYER
With regards to my stories (especially those from my time in Malaysia), I know they seem a little "over the top" but believe me they happened. There were a group of very dedicated locals and expats flying in Malaysia during the 90's and we regularly flew off building sites around the capital Kuala Lumpur. Now on that vane did I tell you about visiting the World Model Shop in HK during this time and the interesting times I had with Cindy and Tom. I still have visions of buying 10 metres of Baron covering (ex USA) of the roll rather than in the little amounts I am forced to buy these days. Lastly the workshop is almost finished, the 2.4 metre square bench for the middle of the shop is finished, shadow boards installed just got to lay the floor covering and it will be up and running.
Old 05-27-2014, 04:06 PM
  #26586
SrTelemaster150
Capt Lou
The FA-150 is a great engine. I would opt for the FA-180 myself. Same size footprint & slightly lighter.
Old 05-27-2014, 06:33 PM
  #26587
jeffie8696
jeffie8696's Avatar
I checked my records and its the 12X5 K series on the PT17 with my Saito 50. Flys great, I think I will try it out again this week.
Old 05-27-2014, 10:13 PM
  #26588
Ernie Misner
Ernie Misner's Avatar
Good tuning things might even happen if rotating that engine put the carb more in line with the tank center.
Old 05-27-2014, 10:21 PM
  #26589
Ernie Misner
What all tends to rust inside of a Saito if abused? I bought a "new" 100 from a guy a while back for a fair (I thought) price. I finally got around to pulling the backplate and rocker covers off and this thing is seriously rusted all over the place!!! Even the valve springs are rusty and it has grown into globs of black crud everywhere. Apparently he had fired it up on the test stand just for a few minutes and then stored it in a wet environment with no after run oil whatsoever. Lesson learned, always pull the backplate off before buying a "new" engine. So.... worst case senerio what all might it need?
Old 05-28-2014, 02:32 AM
  #26590
SrTelemaster150
It puzzles me as to what these people must be doing to engines to have them rust up so severely.
I crashed my PT-19 & chucked it into an un-heated shed on the back of the garage for over 10 years. I didn't even drain the tank let alone inject any ARO into the FA-150 in the cowl. Even though the engine had full synthetic Cool Power fuel used since shortly after being placed into service, the only parts that were rusted where the bearings & they were only lightly coated W/rust. I live 60 yards from a rapids on the St Regis River. It is a very humid environment.
Rust ts can be removed from the valve springs unless they are severely pitted. Bearings are probably the only parts you will have to replace unless the crank journal is rusted. Have a look at the wrist pin also as well so the rocker arm pins & the bores of the rocker arms. The ring may or may not clean up.
Old 05-28-2014, 03:37 AM
  #26591
Rudolph Hart
Hi ernie i spose you could clean the pushrods up and maybe the rocker arms and cam.New valve springs and look at the seats around the sharp edges where it is chromed.New bearings as you know,and you can still get good value out of the old bearings once they are out.Put both of them in the bottom of a deep glass with two ice cubes and splash a drop of bushmills whiskey on top...wait thirty minutes and then skull it with an after shot of castrol r buddy
Old 05-28-2014, 09:01 AM
  #26592
AeroFinn
Hello guys
I just maidened a Hangar-9 40-size Saratoga with a Fa-125a on it. Nice power to weight ratio.. I'm running the engine with a 15 x6 APC. The throttle management is a must, definitely..
-Artto
Old 05-28-2014, 01:58 PM
  #26593
FNQFLYER
With the rusty bits (apart from bearings) if you have access to an ultrasonic cleaner it is a good way to go to get the bits cleaned. I would suggest if you go this route, soak all the bits in degreaser first (o/nite) before you ultrasonic them. Works (most times) for me and you get a better idea what you are up for with minimum effort.
Old 05-28-2014, 04:50 PM
  #26594
SrTelemaster150
Originally Posted by AeroFinn
Hello guys
I just maidened a Hangar-9 40-size Saratoga with a Fa-125a on it. Nice power to weight ratio.. I'm running the engine with a 15 x6 APC. The throttle management is a must, definitely..Gh
-Artto
I thought my 40-size Night Hawk was over powered W/an FA-91s, (15 X 6 @ 9700 RPM) but you have taken it to a whole new level.
Old 05-28-2014, 05:36 PM
  #26595
jeffie8696
jeffie8696's Avatar
At my club the old saying that too much power is just about right , well, you know.
I don't subscribe to it myself .
Old 05-28-2014, 05:50 PM
  #26596
blw
blw's Avatar
+1
Old 05-28-2014, 10:30 PM
  #26597
AeroFinn
Your 91s with a 15x6 at 9700 is a very impressive engine. I assume this with CDI. My Fa-125 is still on GI and the engine has run 2-3 gallons through it. The peak rpm with an Apc 15x6 is about 9450. I think the the engine is more a torquer and with the 15x6 the engine goes beyond it's torque band. And by the way, there is a video clip in CH Ignitions's youtube channel on a Fa-125a with CDI running on glow fuel and an Evo 15x6 prop. The idle is about 1300 and the peak is 9500 or so. This is with timing at 30° before TDC.
Old 05-28-2014, 10:37 PM
  #26598
Ernie Misner
Good question, I dunno how in the heck it got so rusty and looked absolutely brand new on the outside. What about the cam and lifters, anyone ever seen any rust there? I haven't gotten inside of it yet.
Old 05-29-2014, 03:13 AM
  #26599
Rudolph Hart
Hello guys
-Artto
Respect brother,did you use the standard control throws or heaps more?
Old 05-29-2014, 03:26 AM
  #26600
Rudolph Hart
Capt Lou
If you do build that deccy it would sound so good with the 150 in it.The 150 is no different to any other saito re running and tuning.Hobbsy has an early hi compression 150 that gets a bit cranky at times.The modern singles are ***** cats.the 30 with an airbleed carb scares me more than a 220 the cranky little so and so.It's only got a 10x6 prop on it is that wimping or whatEven if you fly it with some other engine they sure handle good
