Welcome to Club SAITO !
Old 03-05-2019, 08:13 AM
  #39226
Captcrunch44
Originally Posted by Jesse Open
Confusing this old guy!
What crank do you think you have?
The 120 crank is 2.7mm shorter stroke than a 150.
The 180 crank is 1.1 mm longer.
The bores are 2mm from one to the next IE: the 120 is 32mm, the 150 is 34mm and the 180 is 36mm bore dia.
well
i will have to check this out again when i get home.
The parts 150ís piston was a tad smaller then the 150 i am repairing. Didnít really give it much thought to the difference. I just put the newer 150 head and piston on the old case.
Now if the stroke is that much different it will end up with a low competition 150. Now question there is will it be so bad that the 150 will now be a 122. And have no power or will it be close enough.
Now with the information that you all have given me I believe i was sold a 120 parts engine not a 150. Oh well
if it turns out to be a dog then i will order the 150 crank and start over.
I noted that the damaged crank is also bent internally so that would explain the broken crank pin. I donít know if the case is damaged it was just easier to take two and make one.
Like i say i will run this engine and see how it does.
Tonight when i get home i will Measure the old piston and we all will now if i got a 120 or a 150.
Dam Ebay buy ten things and get one bad. Lol
Old 03-05-2019, 08:17 AM
  #39227
Jesse Open
Jesse Open's Avatar
What ever method you find easiest, the check is even easier. Bring the crank to TDC on the exhaust stroke and look for a very symetrical action on the intake and exhaust rockers as you rock back and forth from TDC.
Old 03-05-2019, 08:24 AM
  #39228
Jesse Open
Jesse Open's Avatar
Originally Posted by Captcrunch44
well
Like I said before, I have a 150 crank with a very small runout on the shaft, outside of the bearing area. Real easy to straighten. Yours if it help.When you say "smaller" do you mean in diameter????
There are no Saito pistons I know of that are within less than about 2mm of the 150 piston diameter. The 120 will be 2 mm smaller, the 180, 2mm larger. Not much fudge room there! The stroke should be the same on any 150 AFAIK.
Old 03-05-2019, 09:21 AM
  #39229
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
This set up gets moved for each rib.
Keeping things square using squares on Sig Mid Star kit for a future Saito 50.
56 cylinder lookin good once again
Old 03-05-2019, 10:35 AM
  #39230
FlyerInOKC
FlyerInOKC's Avatar
Looking good Hobbsy!
Old 03-05-2019, 10:39 AM
  #39231
acdii
check check post
Interesting, tried to post something and it hung with an eventual database error
apparently it doesn't like the link
ht tps : //www.cars.com/vehicledetail/detail/757176720/overview/
Hey Crunch, take out the spaces in the above link, is that one of your trucks?
Old 03-05-2019, 10:43 AM
  #39232
FlyerInOKC
FlyerInOKC's Avatar
That's because the computer hates you and is out to get you!
Old 03-05-2019, 11:16 AM
  #39233
Jesse Open
Jesse Open's Avatar
Sure looks better with paint! A rattle can miracle
Old 03-05-2019, 11:18 AM
  #39234
the Wasp
Originally Posted by Hobbsy
Jim, you can't beat a Battery Tender for quality: https://batterytender.com/collections/chargers, 39 bucks to 685 bucks, lots of choices.
hey Dave, thank you for the link, I looked at a few of their chargers on line but have not seen them all, I didn't know they made so many, but after seeing the ones in your link I just may buy a Battery Tender !!
but you know I am old school, I like to be involved in things, I like the switches and gauges of the older days, and that's what I am lured to. I dislike the switches/gauges on the Battery Tenders, but still I may buy one !! because I know in the long run down the road that will be the better thing to do, they are very good chargers, my brother told me once, that I do not like change,, I guess so.
it's a bit more money but this one will do just what I want !!!!! I will be able to brag about how well it works, not how big it is LOL hee hee hee
https://batterytender.com/collection...20337271767153
Dave, soft Red with flat Black Rocker Covers
Pete, I like AC/DC too, they are great, it;s too bad about the broth !! a lot of energy there.. but go to YouTube and check out "Papa Chubby" the guy is like Angus, like Angus but on American Southern Rock,,, Papa Chubby , man
Jim
Saito engines, yeeaa-baby
Old 03-05-2019, 11:22 AM
  #39235
Captcrunch44
Originally Posted by acdii
check check post
nope
mine was a 1999 F250 super duty burnt umber. And it had a lot of rust on it. Plus 346,000 miles
Old 03-05-2019, 12:33 PM
  #39236
acdii
nope
I had a 1999 dually and want to get another one, this one showed up in your neck of the woods, but has too much rust. I did find one in Milwaukee though that I just might pull the trigger on. I need to call the credit union first to see if they will do a small loan on part of it. I want to keep some cash in reserve in case I need to put tires or other parts on it. The one I found is only RWD though, and would prefer 4WD, but what I find in similar condition and miles are slightly newer and twice the price or more.
Old 03-05-2019, 03:25 PM
  #39237
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
I actually got away with using this guy in Gloss Black, the cylinder wasn't skinned up
too badly. The crank case is going to require the rattle can miracle.
Old 03-05-2019, 03:32 PM
  #39238
Glowgeek
well
Doubtful the 150 jug will run correctly, if at all on a 120 crank Crunchy. You would not only be loosing displacement (cc), and overall compression (ratio), you would also be widening the quench zone at the top of the stroke. You need a tight quench zone to ensure proper flame propagation. Wouldn't hurt anything to try it though.
Old 03-05-2019, 05:13 PM
  #39239
Captcrunch44
Well itís definitely a 120
i will still run it and see what happens.
Should be uneventful. So now i need to order a crank
sorry I really donít want to mess with a slightly bent one, if it was for me I wouldnít care but for someone else needs to be good.
Old 03-06-2019, 12:55 AM
  #39240
Rudolph Hart
Rudolph Hart's Avatar
Dave that's a nasty trick to play on gary,he did'nt look to hard at the shape or top of your 'rattle can' fooled me as well i thought it was a pre mixed squash and use 2k product,did you brush clear on as well?
Okc ain't no one sane here..
Old 03-06-2019, 02:53 AM
  #39241
Jesse Open
Jesse Open's Avatar
What?
That little sin hider doesn't have a rattle.?
Oh well, you could dip it in a bucket of paint and hang it on a clothesline and the result is about the same
https://www.ebay.com/itm/Vintage-SAI...cAAOSwzt5baq1M
Here is another painted Saito that needs "touch up" frome a rattle can... Only $1200 on eBay right now!
Old 03-06-2019, 04:54 AM
  #39242
Captcrunch44
Call me a tight ass but how does one justify the cost of that engine? Just because it fits in a car
Old 03-06-2019, 05:00 AM
  #39243
Jesse Open
Jesse Open's Avatar
And you still have to paint the top half.
Or better still, strip the bottom
Old 03-06-2019, 05:30 AM
  #39244
Captcrunch44
You know funny thing
i think thatís the way they come or there sure a lot of rebuilt ones out there and there all stupid expensive. Would a 60cc gasser would be way more fun
Old 03-06-2019, 05:36 AM
  #39245
Jesse Open
Jesse Open's Avatar
Looks to me like someone at Saito couldn't make up his mind. Perhaps a Bi-Polar designer.
Old 03-06-2019, 08:17 AM
  #39246
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Saito 30 SC variant
It appears that the 30 SC variants all look like this.
Old 03-06-2019, 08:27 AM
  #39247
acdii
Aww aint that thing cute.
Old 03-06-2019, 08:37 AM
  #39248
Jesse Open
Jesse Open's Avatar
Saito 30 SC variant
Oh, I was pretty sure of that already
Old 03-06-2019, 08:57 AM
  #39249
Captcrunch44
I still canít believe they make something for a car and itís three times the price of a airplane engine.
What do they do different. What does a car engine have the an airplane engine doesnít?
With that said I still like the price of the airplane engine they can keep there car engines
Old 03-06-2019, 11:31 AM
  #39250
the Wasp
Saito 30 SC variant
isn't that a BSA engine ?
I guess not
Jim
