Welcome to Club SAITO !
TX
Thank you very much!
The sound on the video is off, compared to the actual sound which is waaaayyy more sweeter. hahaha. It sounds like a song that i will listen over and over again. hahaha, sorry i'm just happy with it. Thank you, Jesse, for selling it to me. i love the balloon popping sound at low idle.
TX
I have one question, but i will have to make a video i think for you to understand to see if i have a problem or what, so when is running, the right head burnt fuel is coming out of the valve housing tru the top screw, I took the valve cover off and inspect and everything looked fine and tight to me, but i have fuel coming out of there and not the other head and i don't even know what it could be.
Any idea of what it could be, opinions are really appreciated.
The 100 twin has a check valve controlled, cam driven diaphragm pump. It can develop a good head of pressure if there is a blocked outlet. Under normal conditions, there should be very little leakage at the covers.
Pressure to where? Never owned pumped engine, I assumed the pump pressure went to the fuel tank and the engine was normally vented. No?
Not to tank.Not recalling the routing right now. I don't actually recall if the pressure or intake side went to case. Without venting I suspect blowby on an engine not yet broken in could be considerable as well.
Update,It is in fact pressure fed to case.
Ooooh I see, it's not a boxer style engine. With both pistons traveling in the same direction it sure enough would not develop enough case pressure to evacuate excess burnt fuel/oil from the case. The pump solves that. Very interesting, thanks.
Could it be the pump is dry and needs primed to start working? That happens with some 2 stroke gasser carbs when they're left dry all winter.
EDIT: Nevermind, I forgot it's an air pump.
Maybe one of the pump valves is stuck open or you may have to spin the engine with a starter to feel any pressure out of the vent.
try removing the nipple to see if something is blocking the vent hole on the inside of the case,
another thing, you can try priming (with oil) the front of the case thew the vent hole
edit, with all this twin talk I had to get my 100 Twin out and put it on the desk by my monitor
Jim
TX
I wouldn't run it much if you are not getting oil out of the front vent, you do not want to destroy that front bearing and cam. and I am wondering if you are getting more oil in the rocker cover because the oil is not getting to the front, here are a couple things to try,
Jim
Jim
Im going to try that
guys, I think I have decided on a name for my VQ P-40, "Bad Joe", as in G.I. Joe. I was thinking of adding "With a Gun", but I'm not sure on that, it seams a bit too long, so at least it's Bad Joe for sure.
what you think ??
Jim
what you think ??
Jim
