Welcome to Club SAITO !
Old 10-10-2019, 03:43 PM
  #42701
Captcrunch44
Yeah it’s amazing the skills some people have. I just sat in awe at Gary’s skills.
Old 10-10-2019, 05:26 PM
  #42702
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Hey Cap, I received the new Rascal 110 fuse, I am toying with rigging a mock up of the 182 on there, what do you think? No drilling holes until I commit comfortably.
PS, as I checked out that 65 fuel inlet I checked 4 older HS needles, they all have sharp points except the 65 which is more blunt like the one Gary shows.
Old 10-10-2019, 08:02 PM
  #42703
Captcrunch44
the 182 I have is pretty awesome would look great on there
will the cylinder’s stick out?
The 65 will probably just get a different carb and will set the original aside.
Old 10-10-2019, 10:35 PM
  #42704
Rudolph Hart
Rudolph Hart's Avatar
Originally Posted by FlyerInOKC
I don't know about anyone else but I'm really impressed!
Mike
Agreed, it's hard not to admire the range of skills gary has mastered taking other work he has shown here into consideration.
ps gary there's an old saying 'no man is an island' did the norwegian princess lend a helping hand?
Old 10-11-2019, 03:08 AM
  #42705
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
I have couple of extra 82 carbs, I can trial fit one if you'd like.
That fuel inlet by Gary is master piece enough to treasure.
I have new crankshaft coming for the 82 fixxerupper. I mounted to 1.82 on the PSP to do a limber up and test run. It will have straight, black pipes on it.
I took somebodies advice and resisted the temptation to paint the cylinders black
Old 10-11-2019, 03:53 AM
  #42706
Captcrunch44
lol
yeah there are just some engine’s you don’t paint.
I see what Gary did and I found a needle assembly from a 150 will screw into the carb so I need to make the orifice and solder in the place.
The 182 I have has CH ignition and run’s good but it needs to be run and broke in. I hate to copy Dave or Gary but I am considering getting a 110” Rascel also to test engine’s on. Providing it fly’s as good as the 168” Rascel, witch I think it does.
Old 10-11-2019, 04:05 AM
  #42707
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
All those big Saito V twins.
Let us know how it goes., the new 110 Rascal fuse came in a box that weighed 21.3 pounds, to say it was well packed is a huge understatement.
Big doins here in Colonial Beach, Va. a town of 3,600 is hosting 30,000 bikers for the CB Fall Bike Fest. Go figure.
Old 10-11-2019, 04:06 AM
  #42708
Glowgeek
Dave, that 182 is a thing of beauty. Dual airbleed carb huh? Hard to tune for idle?
Old 10-11-2019, 04:09 AM
  #42709
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Easy Peazy, set therm halfway across the hole and your very close to done. And Thanks
I only had two Glow Devil plugs, so it has two Glow Devil's and two Fox Miracles in it.
Old 10-11-2019, 04:28 AM
  #42710
Captcrunch44
Yeah my 182 same way pretty easy halfway across hole and maybe a little tweak and it’s done.
The air bleed carb is just stupid easy, I think that’s why some have a problem with it.
By the way when I got my 182 the guy must have had trouble with the engine. I can tell the air bleed screws were all the way out. Tried it that way for kicks and nope wouldn’t idle so screwed in to half hole and done. The engine is so new that it won’t idle down to were we like so need run this thing and hope to in joy the plane providing the covering stays on.
Old 10-11-2019, 04:31 AM
  #42711
Glowgeek
Dave & Crunchy, where are the airbleed holes located in relation to the throttle barrel? Are they only exposed to vacuum at idle and then closed off when the barrel is advanced or are they lower down on the carb body and exposed to vacuum at all times. I have seen them positioned in various locations on other engines. Just curious.
Old 10-11-2019, 04:37 AM
  #42712
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
I'll have stew on that a bit, I'll report back. Something that might be a problem using the 182 is that the upper left mounting bolt hole is nearly at the top edge of the fuse. The upper left bolt hole when using the 180 is not quite so high.
Old 10-11-2019, 04:53 AM
  #42713
Jesse Open
Jesse Open's Avatar
lol
Too bad you don't live nearby. I have one that I would give you.
Dave, some triangular stock blocks, epoxied in place around the top of the firewall can be helpful. A few high- time Rascal 110 are showing up with loose firewall tops. The landing gear blocks, like with many Seagull built ARF can be a weak point too.
Old 10-11-2019, 04:54 AM
  #42714
Glowgeek
To check the airbleed location you can use a T-pin through the hole and rotate the throttle barrel.
Can the 182 be mounted slightly lower on the firewall and the cowl tipped downward slightly?
Old 10-11-2019, 04:57 AM
  #42715
Captcrunch44
the Saito 180 mount has the same foot print as the 192
if that matters. I should also say with the 180 side mounted
Old 10-11-2019, 04:59 AM
  #42716
Captcrunch44
yes as you advance the throttle the air bleed is closed off
Old 10-11-2019, 05:04 AM
  #42717
Glowgeek
Thanks Dave.
Old 10-11-2019, 05:06 AM
  #42718
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
I love it here, no cows and no trees.
I gotta take the one quarter Cherokee Mrs. to aqua therapy then I can get serious about all that. Busy busy.
Tomorrow AM I am meeting my brother in law and sister in law in Waldorf, Md. for breakfast at Ape Hangers, then attending the Bike Fest with them.
I used to fly up there at the southern most part of Andrews AFB, now I fly about 35 miles south of here.
Old 10-11-2019, 05:09 AM
  #42719
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Perhaps my quicky trial fit of the 182 was two quick. When I am not so rushed I'll do better.
Old 10-11-2019, 05:34 AM
  #42720
FlyerInOKC
FlyerInOKC's Avatar
I use to work for a company out of Waldorf, MD. Its a nice area.
Old 10-11-2019, 05:55 AM
  #42721
Jesse Open
Jesse Open's Avatar
Dave,
You could try the 182 on the Rascal without cowl. That way it would be a snap to fit a single later on and not need to buy a new fifty dollar cowl.
Just a thought.
Looks like a pleasant trip ahead for you and the brother and his Missus
Old 10-11-2019, 08:17 AM
  #42722
acdii
Supposed to be cold here tomorrow. Right now it is 42*, was 49* when I arrived at work. I have a couple things I need to get done outside tomorrow, then the rest of the weekend will be in my shop finishing up my Liberty Sport.
Hey Mike the Crunch, are you interested in building a Liberty Sport from a short kit? I am almost done creating the burn files and want someone to sample build one besides me. Would make a great little plane to mount a Saito on.
Old 10-11-2019, 08:38 AM
  #42723
FlyerInOKC
FlyerInOKC's Avatar
I'm very tempted! The Liberty Sport is a great looking plane and the plans and manual are available for download.
We had our first freeze last night and only going to 52 today.
Old 10-11-2019, 08:43 AM
  #42724
acdii
I'll give a shout when I have the first test kit cut out. So far I have the wings built out, and have a few corrections to make on the ribs, but I used the kit parts for the fuse, so need someone to build a fuse to verify fit and form.
Old 10-11-2019, 08:47 AM
  #42725
Glowgeek
Is that the Sig Liberty Sport that they call the "Exact Scale" with the 57" wingspan?
