Welcome to Club SAITO !
Old 07-06-2020, 02:24 PM
  #46801
So I use a hanger 9 starter with a 4 cell LiPo.
I sent him same set up. He puts 4 cell pack in something else and tryís to use a whole bunch of different battery combinations that didnít work so he buys big ass magnum something starter puts a 4 cell Lipo on it and now he can start his engines But allís is trying to start 30cc size engineís.
the plane is some sort of vintage race plane that had floats. That were taken off to be a land based plane.
and yes we filed a 337 with the FAA
Old 07-06-2020, 03:52 PM
  #46802
I pulled the 4*60 wing down to replace the retracts, and will need to beef up the pivot brackets, they broke loose. Still need to get the Saito 90 run up, haven't started it since I got it. I think it will run.
Old 07-06-2020, 04:01 PM
  #46803
Might not be a terrible idea to open it and check for rust real quick? Nice engines but they all hate rust.
I killed a used 56 and a 62 due to rust. They both felt pretty smooth before I started them. Just say'n.
Old 07-06-2020, 04:05 PM
  #46804
Already took it apart and cleaned it, everything looked good, just a bit gummy from Castor.
Old 07-06-2020, 04:07 PM
  #46805
I knew you were all that. Don't even know why I posted it.
Old 07-06-2020, 04:09 PM
  #46806
Anyone heard from our outlaw friend down under?
Old 07-06-2020, 04:12 PM
  #46807
FlyerInOKC's Avatar
Anyone have an idea how much run time a Saito .50 will get at 3/4 throttle with a 6 oz tank?
Old 07-06-2020, 04:23 PM
  #46808
I've run an fa45 for 20 min on an 8oz tank with varying midrange throttle and a few wot passes. Plenty of fuel left for landing. I'm guessing here but I think an fa50 would run 12min or so at 3/4 throttle on an 8 oz tank. A lot of that has to do with needle settings though. Recommended tank size 10-12oz.
Old 07-06-2020, 05:12 PM
  #46809
30-40 minutes more of cut back to 1/2.
Old 07-06-2020, 05:34 PM
  #46810
I know what an FG-11 with a 12oz tank will do. About an hour or more.
Old 07-06-2020, 05:47 PM
  #46811
FlyerInOKC's Avatar
Thanks! I was trying to decide what size tank I need for my Tiger 2 if I put a Saito .50 on it.
Old 07-06-2020, 06:23 PM
  #46812
Originally Posted by Glowgeek
She's already shot me once, not kidding, but it was an accident............I think?
oh, I see,,,,, she missed LOL
Jim
Old 07-06-2020, 06:24 PM
  #46813
An FA50 will fly it, an FA62 will wake it up and reveal it's true potential. Just my take on it. Most people fly them with ,46 to .55 size 2 strokes which both make a great deal more power than a .50 4 stroke. Again, just my preference.
Old 07-07-2020, 12:12 PM
  #46814
Ok what size straight pipes fit a 200r3?
Old 07-07-2020, 04:18 PM
  #46815
Measure the OD of your header?
If you don't have the header it's trickier. Measure the inside diameter of the exhaust port and then add 2.17mm and then round up or down to the closest mm.
For thread pitch: count how many full threads there are in a 10mm length of threading. If there's 10 full threads then it's a 1mm thread pitch. If there's 8 full threads then it's a 1.25mm thread pitch.
Old 07-07-2020, 04:48 PM
  #46816
My Feedback: (149)
The FA45S thru FA62 has 10x1 thread and the FA65 tru FA100 has 12x1 threads. My 170R3 has 10x1 threads. I'm guessing the 200R3 is 12x1
T-Man49 in Al
Saito 723
Old 07-08-2020, 02:50 AM
  #46817
My Feedback: (102)
Hobbsy's Avatar
Here is a Tech note from MacGregors: Muffler (Left) for Saito FA-170R3 and FA-200R3 Four-Stroke Radial Glow Engines.
A picture for proper installation.
Old 07-08-2020, 03:12 AM
  #46818
Tower Hobbies specs for the 200R3 state that the muffler threading is M12x1.
Looks like Triumphman made a good educated guess?
Old 07-08-2020, 03:18 AM
  #46819
Funny!
Old 07-08-2020, 03:21 AM
  #46820
My Feedback: (102)
Hobbsy's Avatar
Here is from the 200 manual
Bore: 1.06 in (27.0mm) Crankshaft Threads: 8 x 1.25mm Cylinder Type: AAC Cylinders: Radial Displacement: 2.00 cu. in. (32.98 cc),2.00 cu. in. (32.98 cc) Engine (Only) Weight: 46.4 oz (1366 gms),46.4 oz (1366 gms) Muffler Type: 10mm Flex Exhaust Pipes included Muffler Weight: 4.4 oz (125 gms) Prop Range: 16 x 8-10 17 x 6-8 Recommended Fuel: Glow Stroke: 0.76 in (19.2mm),0.76 in (19.2mm) Total Weight: 50.8 oz (1440 gms),50.8 oz (1440 gms)
I think the 12 mm is for the gas engine with the black elbow adapters.
Old 07-08-2020, 06:30 AM
  #46821
My Feedback: (102)
Hobbsy's Avatar
Engine run, home brew Saito 50 GK made from spare parts, new crankcase.
Saito 50
Prop===Xoar 12 x 6
Fuel===Wildcat 10% with 18% full synthetic
Plug===Glo-Devil 4c Special for Saito and Enya
Exhaust Early Cast
Max rpm. two clicks rich of slightly unsteady peak.==10.200
Idle======2,050 rpm
It has a great, clean midrange. I didn't expect 10 +.
Ignore picture #2, it's a different engine.
Old 07-08-2020, 07:20 AM
  #46822
FlyerInOKC's Avatar
That is a very respectable performance on the .50!
Mike
Old 07-08-2020, 09:04 AM
  #46823
Same thing happened to me when I ran Crunchy's 50. Over 10k with a 12x6 is FA56 territory! IIRC, his 50 was only 100 rpm shy of the last 56 I had.
I can't remember, does the 50 have the fuel metering slot at the back of the throttle barrel? All the ones I've run that had that had a clean midrange.
Old 07-08-2020, 11:22 AM
  #46824
My Feedback: (102)
Hobbsy's Avatar
Thanks Mike, I sent a slightly stronger 50 to a friend yesterday, I hope that guy's tach reads like mine.
Lon, I've never seen what you describe as a slot in the back end of the barrel, except on a 65.. You happen to have a picture.
Old 07-08-2020, 01:41 PM
  #46825
Yeah, that's it Dave. I guess I must remember that from the 65's. Best carb ever, wish they were all like that.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
