Welcome to Club SAITO !
Old 08-31-2020, 06:35 PM
  #47701
Jesse Open
Jesse Open's Avatar
I need to go back to work.Retirement isn't for sissies.
Old 08-31-2020, 06:51 PM
  #47702
FlyerInOKC
FlyerInOKC's Avatar
Are you pass the point where you ask when you found the time to work for a living?
Old 08-31-2020, 07:07 PM
  #47703
FlyerInOKC
FlyerInOKC's Avatar
Open rocker FA-30 for $100 anyone? It even has the chock assembly.
https://www.rcgroups.com/forums/show...ines-30-to-1-2
Old 09-01-2020, 01:55 AM
  #47704
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Dave,
More house cleaning of parts and engines. Came across these 10mm male x 12mm female exhaust adapters as well as a pair of 10mm male pipe nuts that work great with 1/4" brass K&S tubing. Can you use them?
BTW, yes I also found a complete big block muffler and a 13mm body that you can make a tail for and tap out to 14mm. I do think you wanted those.
Yes sir, I could use another 14 mm muffler for a 120 sized engine shoot me a PM for money talk, Thanks
Old 09-01-2020, 01:59 AM
  #47705
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
We may just have to accept a little binomial nomenclature where the prop driver is concerned. Fun eh.
Old 09-01-2020, 03:56 AM
  #47706
Jesse Open
Jesse Open's Avatar
I always have recognized both terms. It wasn't I who questioned the correct use of "hub".
Not so with collet however.
No money needed, just send your address.
Old 09-01-2020, 12:31 PM
  #47707
Glowgeek
Default 120 Fathead trouble
You all may remember me receiving a low time 120 fathead. Tore it down and verified it was low time, very low time. The factory honing marks in the cylinder were like new, could barely see where the piston ring had run. The edge of the piston ring still has very sharply defined factory grinding ridges. This engine was obviously broke in and set aside for many years as it had a good deal of rust on the bearings and crank.
Anyway, I cleaned everything up, installed new bearings and set the timing and valve lash. All good UNTILL I tried to install the rear cover. As I tightened the screws the crank locked up hard. What the heck, I forgot the rear cover gasket? Nope. Hmmm, must not have seated the bearings properly, nope. Crud stuck between the pinion gear and crank shoulder? Nope. Crud between the spacer and pinion gear? Nope. Pissed off I gave up on it late last night.
This morning I removed the cylinder and decided to check for crank pin centering. Sure enough, the crank pin measured dead center of cylinder bore! What the deuce?!
Is it possible the rear cover is from a later engine? Anyway, my fix was to machine .008" off of the inside of the rear cover. All good now, engine runs spectacular.
Old 09-01-2020, 12:35 PM
  #47708
FlyerInOKC
FlyerInOKC's Avatar
Good to hear you solved the problem! What are you plans for the Fathead, do you have a airplane in mind?
Old 09-01-2020, 12:56 PM
  #47709
Glowgeek
The 120 Fathead is a perfect engine to use on 60 sized warbirds that need a morw weight up front to balance out. Hellcat, Bearcat, Corsairs etc. Also good for WWl bipes. Fresh out of any of those and it's not strong enough to fly my 60 size P-47 the way I want it to fly.
I just bought it for the experience. When I tire of it off to the marketplace it goes along with the a half a dozen of my other recently overhauled Saito engines.
Old 09-01-2020, 01:13 PM
  #47710
Captcrunch44
had the same problem with 150.
there is definitely something different between I case and back plate and an other. Swapped out the back plate with the other engine and all was good.
Old 09-01-2020, 04:45 PM
  #47711
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
I had that back plate rubbing problem on one of the 120's, the rear bearings was about 1/64th" from being fully seated. It wouldn't pull in when tightening the prop, I had to finish pressing it and all was well.
Cap, your engines are on the way, tracking # by PM. Thanks
Old 09-01-2020, 05:27 PM
  #47712
Jesse Open
Jesse Open's Avatar
Plus 1 on that.
Old 09-01-2020, 05:32 PM
  #47713
Glowgeek
The crank will never pull the rear bearing in all the way if the front bearing is fully seated, it must be set fully with a press or with a drift punch. The front bearing controls the location of the crankshaft within the case ie the inner race of the front bearing is capured between the crank shoulder and the flange collet. (Did you see that Gary?). When everything is seated properly there is an intentional gap left between the crank counterweight and the rear bearing. The gap is there to accommodate thermal expansion of the case as the engine heats up. Kind of a scary thought but the inner race of the rear bearing actually slides rearward on the crank as engine temp rises!
Edited first sentence.
Old 09-01-2020, 06:17 PM
  #47714
the Wasp
now with pride and assurance you can now change you user name to Fathead Saito LOL
Jim
Old 09-01-2020, 06:54 PM
  #47715
Jesse Open
Jesse Open's Avatar
That 1/64" or .016" off seat that Dave mentioned is far more than any ends play that Saito may have designed in. Properly installed, both bearing outer races would be bottomed in their bores.And yes, I always heat the engine housing when installing bearing outer races.
A little side shot from 1979, USI Clearing Detroit Service Center Back in the heavy machine repair, sweat shop days. The iron link was heated with a ring burner for four hours. The two bronze half bushings were packed in dry ice at the same time. We lowered the bronze into the housing on tongs hung below the crane. Four or five men with maple blocks and 5 pound rawhide hammers would drive the bushings home together very evenly. You had one shot at it. Get it skewed and we were screwed.
Old 09-01-2020, 07:07 PM
  #47716
FlyerInOKC
FlyerInOKC's Avatar
Impressive!
Old 09-02-2020, 02:46 AM
  #47717
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Saito Buds, I received a heavy phone call from my daughter in W. Va. at 5:55 am, her youngest son died from a drug overdose. He was 25, I'll be gone for a few days. He is to be cremated with no kind of service. I'll go to support my daughter and her other four kids.
Old 09-02-2020, 03:08 AM
  #47718
Captcrunch44
oh wow my thought’s and prayers go out to you and your family and especially your daughter.
  #47719
Glowgeek
Oh no, so sorry to hear that Dave. Tragic at such a young age. Be safe out there my friend.
Old 09-02-2020, 03:55 AM
  #47720
Jesse Open
Jesse Open's Avatar
Dave,
My heart goes out to the entire family, especially mom and dad. The loss of a child is a horrific experience.
Old 09-02-2020, 04:09 AM
  #47721
Glowgeek
That bearing press is sweeet.
I have measured face to face of the bearing bores and face to face of the crank shoulders of several engines. Taking the delta of bearing thicknesses into consideration the clearance ranged from .006"-.009" on all except this almost brand spanking new Fathead, it measured .016". I measured and re-measured but that's what it is.
Either Saito designed it that way or there was a slip up in QA. As new as this engine is I seriously doubt the crank or rear cover was swapped out by someone but you never know.
Old 09-02-2020, 05:18 AM
  #47722
Jesse Open
Jesse Open's Avatar
If I thought Saito designed that way, I would never own one. A minimal preload for this setup is quite acceptable. No room for .016" slop.
Thanks for the comment on the bearings press.
Old 09-02-2020, 05:25 AM
  #47723
FlyerInOKC
FlyerInOKC's Avatar
Heart breaking Hobbsy! I wish you and your family all the best in this difficult time!
Mike
Old 09-02-2020, 05:57 AM
  #47724
Glowgeek
Slop? No slop, unless you're using that term loosely to describe designed in clearances to offset cumulative tolerances.
There is no room for preload during cold assembly imo. I wouldn't want minimal preload cold and have side loads increase as the case expands. Saito didn't design it that way, neither did OS, Enya, YS or any of the clone manufacturers. The gap is intentional and necessary. Does it need to be .016"?, definitely not, .006"-.008" seems like plenty to allow for case expansion and machining tolerances.
Old 09-02-2020, 06:13 AM
  #47725
Jesse Open
Jesse Open's Avatar
Care to educate me?
Slop would the outcome either way, be it bad geometric tolerances or shabby parts.
I am not inferring Saito intentionally made the slop, It is you who assumed they did.
Been doing this far too long to be baited into an argument with you. Worked with fitting and assembling. bearing setups from these toy engines to precision machine spindles to huge metalworking press bearings.
All good designs also specify the shaft and housing fit as well as the class of internal bearing clearances. Those clearances allow for the changes that take place when interference fitted on shafts and into housing bores.
Geometric Dimensioning and Tolerances is the actual, accepted practice. Properly applied, that .006" to .008" you prefer would be the final result, nothing outside that range.
All of that aside,back to the original thrust of my first comment;
In this application, a properly installed bearing should be seated with its outer race against the shoulder of the housing bore.
Go ahead, ignore that. Look for what you "want" .
Just like trying to explain the cam lobe position to you, I am done.
