Welcome to Club SAITO !
Old 05-05-2007, 10:41 PM
  #7201
My Feedback: (16)
w8ye's Avatar
Default RE: Welcome to Club SAITO !
Both numbers you quote are plastic. There is no aluminum one. You want the latest "A" version. Also you need metric washers under the back plate screws. Order the carb O ring kit also. Use the Viton O'ring at the head end of the intake.
Old 05-05-2007, 10:46 PM
  #7202
What is the diffrence with the A version?
Old 05-05-2007, 10:49 PM
  #7203
My Feedback: (16)
w8ye's Avatar
Where the tab is for mounting the carburetor, there are two braces underneath on each side of the top left backplate retaining bolt. Also the material is harder.
I have seen some of these reinforced back plates that have been around a while be bad also.
The 82 uses the same backplate yet I haven't heard of a bad 82?
Old 05-05-2007, 11:07 PM
  #7204
No reinforcments under my carb mounting tab, must be old style. i just ordered a new style backplate. Also what is your thoughts on the 80? I am looking at a good used one for my cg cub.
Old 05-05-2007, 11:12 PM
  #7205
My Feedback: (16)
w8ye's Avatar
When you remove the old back plate you will find that the corners are warped and the mounting holes have been squeezed in upon themselves by the pressure of the small contact area of the heads of the Hex socket (Allen) bolts.
Old 05-05-2007, 11:16 PM
  #7206
TimC's Avatar
I noticed when I removed the backplate on my .82, loctite was used on the screws at the factory. I assume the reason was to allow much less torque on the screws than normal to keep from squishing the backplate flange.
Old 05-05-2007, 11:20 PM
  #7207
My Feedback: (16)
w8ye's Avatar
Even though the 72 and the 82 have the same back plate, the design of the intake manifold is a little different. The 72 intake manifold has a thin flange at the top for the retention of the aluminum washer. This washer will wear out and move away from the seal are. The 82 intake manifold is larger in diameter.
Old 05-05-2007, 11:23 PM
  #7208
blw
blw's Avatar
The screws back out of my .72 after one engine run. I used epoxy instead of a thread locker and it has worked fine since. My .82 had some sort of locktite on the threads too.
Old 05-05-2007, 11:33 PM
  #7209
freeonthree's Avatar
My 80 has a bad intake tube, so I just epoxied the tube to the cylinder, with a nice bead all around. It never comes loose, and if ya need to remove it for some reason, the epoxy can be removed easily with an exacto. It doesn't stick to the metal good enough to be a problem, but it does stick good enough to seal the joint untill you want it off. It works so good, I never bothered to order a new intake tube which is like $15.00.
Old 05-05-2007, 11:39 PM
  #7210
My Feedback: (16)
w8ye's Avatar
Some of us are using RTV silicone on the intake tube-head joint as well as the other mods mentioned. Be carefull to not get any inside the engine.
Just put a thin layer on the outer shank of the tube where it slides through the O-ring
Old 05-05-2007, 11:43 PM
  #7211
Yeah, that could be bad. The o ring seems to keep the epoxy on the outside ok, and the epoxy also comes off the o ring easily too.
Old 05-06-2007, 05:44 AM
  #7212
tigil's Avatar
Can you tell me who (wich company) made this little Gile 202 very nice!! this plane are ARF ?
Old 05-06-2007, 06:35 AM
  #7213
tigil's Avatar
Hi William ,I just bought my first Saito engine because the lightweight and really good ratio weight versus power
my question is : can I run this engine with the same fuel then I use in my OS engine ? (power master 18% oil blend 15% nitro) and XP fuel 17% oil blend 15% nitro
Gilles
Old 05-06-2007, 06:47 AM
  #7214
My Feedback: (16)
w8ye's Avatar
If William Robison were still alive he would tell you that you need a little castor oil in both your engines. You can use the same fuel in either.
Old 05-06-2007, 07:16 AM
  #7215
My Feedback: (102)
Hobbsy's Avatar
Jim, speaking of Bill, yesterday I found a little package that I had put together to send to him. He wanted my old cam that came out of my 1.50. He wanted to examine it for wear patterns.
Old 05-06-2007, 07:22 AM
  #7216
blw
blw's Avatar
Tigil, you are member #520.
Dave, guess it was not a good moment to find that cam.
Old 05-06-2007, 07:04 PM
  #7217
tigil's Avatar
Can you tell me how rpm my 82 saito can turn APC 14X6 because I put this engine on showtime 50 6.5 pounds plane and I dont have illimited vertical
Old 05-06-2007, 07:19 PM
  #7218
My Feedback: (102)
Hobbsy's Avatar
Here tis.
ID:	679069   Click image for larger version
Old 05-08-2007, 02:50 PM
  #7219
canardlover's Avatar
ORIGINAL: bkrfrmhell
Question on a saito 72. Can't get it to idle reliably at all. I found the carb would move back and forth with the throttle. O ring seems questionable and I assume it may be sucking air. Also it has the plastic back cover, does anyone know which cover is the aluminum one? SAI7217 or the SAI7217A?
Yes indeed - the plastic back plate on the Saito.72 is a bit flimsy. I beefed it up by adding a piece of aluminium and a longer recessed screw as shown. Now the carb can be screwed tight directly against metal....Cheers/Harald
Old 05-08-2007, 03:09 PM
  #7220
Ernie Misner's Avatar
Do they really make an aluminum back cover for the 72?
Ernie
Old 05-08-2007, 03:32 PM
  #7221
After flying electric parkies for this past two years - I've decided to make a glow bird ( to make sure I won't regret my decision I went and got myself a Saito 125a GK[8D] ). The engine was bench run rich and slow for a couple of tanks per the instructions. The last run it was peaked to about 8400 rpm on a 16x6 APC-Sport. I put in into a Hangar 9 Showtime 4D and brought it out last week for its maiden.
At the field, due to poor lighting I was not able to properly get rpm readings from the cheapo tach - it sounded weaker than on the bench. I left the HS needle out at 3 turns with a smoky rich trail at full throttle. The plane maidened succesfully but felt underpowered even when the recommeded engine was a Saito 100 and I'm using the stronger 125. I found I had to fly near full throttle most of the time. The plane weighed 8 1/2 lbs dry - so it's not exactly overweight. Fuel used is Morgan's CoolPower MV for 4-strokes.
Now is it possible the HS needle is set too rich? ( It was exactly 3 turns out from close - and I did not adjust for fear of leaning it out without a tach reading )
All the 'plumbing' was checked - no leaks. Also, should I be checking the valve clearance at this early stage ?
BTW, I'm not regretting my decision - the Saito is a work of art - incredible throttle response and starts like a champ everytime.
Old 05-08-2007, 04:42 PM
  #7222
My Feedback: (16)
w8ye's Avatar
I'm thinking that a 15-6 would be a better prop candidate?
Old 05-08-2007, 06:03 PM
  #7223
tigil's Avatar
Can I reverse the carb on the 82 Saito to have the high end needle upper side ?
Old 05-08-2007, 06:13 PM
  #7224
tigil, yes you can. I did the same with mine.
Jon
Old 05-08-2007, 06:28 PM
  #7225
My Feedback: (15)
kryptonite
Way too rich by the sounds of it chap.
My Saito singles, I tend to tune by ear and watch the smoke. I like to keep them a little rich on the low end, but lean enough for fairly good transition.
Lean out the HS needle untill there is very little smoke, then back it up 1/8 to 1/4 turn. Run it like this on the ground for a couple of minutes and check the temp of the motor (I do this with fingers on the headers) you should not have to remove yo fingers sharply, it should be very warm, not hot here.
Are you using any sort of muffler extension, if so remove it. I dropped about 30% on my 91, when I fitted an exhaust deflector to the new style muffler.
Paul.
p.s. Does anyone have a spare .91s straight exhaust header?
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
