Welcome to Club SAITO !
Old 01-31-2009, 02:16 PM
  #13701
My Feedback: (16)
w8ye's Avatar
Default RE: Welcome to Club SAITO !
All I know is that the Saito engines have been coming from the factory this way for some time now. The engine in the picture was not made before 2001. It appears to have a lot of time on it but I also know the picture is somewhere around 5 years old.
The all aluminum non bushed rods hold up real well and there are several manufacturers using the high silicon aluminum rods.
Old 01-31-2009, 02:21 PM
  #13702
I am not apossed to running the 220 but i am already buying nitro buy the case byron 30% seems to do the trick for me. What is the fuel consompstion of this motor and what size tank do you have. This decathlon looks to be a great flyer and i want to get more than 9 minutes air time.
  #13703
My Feedback: (18)
retransit's Avatar
OK, thanks.
Bob
Old 01-31-2009, 02:33 PM
  #13704
My Feedback: (16)
w8ye's Avatar
ORIGINAL: Greg R.
Better go for a 30 oz tank
Old 01-31-2009, 03:42 PM
  #13705
ORIGINAL: blw
ORIGINAL: Old Fart
and have you tried an old bsa or trumpy single..
Yes, tried both of them.
I have been kicked by two BSA singles, several horses, and two rodeo bulls. The BSA was the most vicious by a wide margin.
jess
Old 01-31-2009, 05:49 PM
  #13706
I am about to get my red seal in carpentry and for a graduation gift my wife is letting me get the 166cm/65 3/8th" version of the Cosmic Wind from these guys. http://www.modellbau-kuhlmann.de/cosmic_wind.htm
I am planning a Saito 300. Is there anyone out there with any thoughts or input about this plane/motor combo? Also any input about the 300 would be great. Am about to buy the motor. Then I have to come up with 600 Euro's + shipping for the plane.
Apparently there is an english version to this site but I haven' found it.
Old 01-31-2009, 06:10 PM
  #13707
Or would the 300 be better suited for the 206cm version?
Old 01-31-2009, 06:14 PM
  #13708
My Feedback: (16)
w8ye's Avatar
http://translate.google.com/translat...US254%26sa%3DG
Or here is a tinyurl of the same site http://tinyurl.com/d4l52n
Old 01-31-2009, 06:40 PM
  #13709
Hey Guys, I think I just got the buy of a lifetime. Brand NIB Saito100, Hanger 9 Miss America P51, 5 Futaba 3004 servo's, 1 Futaba S138G retract servo, Alum Spinner, and misc. other stuff, all NIB, boxes still sealed $200.
I couldn't get my money out my walet fast enough. Had several other good deals also. He hadn't flown in about 4 years and wife told him to clean out garage.
Old 01-31-2009, 06:46 PM
  #13710
Jim,
That is a deal. At those prices, I would have negotiated for all he had. Good for you.
Jim
Old 01-31-2009, 06:57 PM
  #13711
mike early's Avatar
4 years without flying? How can someone lose interest in a hobby as great as this one?
Old 01-31-2009, 07:06 PM
  #13712
brockettman's Avatar
Jim,
WOW! What a score! I guess we're all looking for one of those package deals........ Congrats!
Ben
Old 01-31-2009, 07:14 PM
  #13713
Banned
Happens all the time now that arfs are so common. Guy gets one as a present or decides he always wanted to fly a model airplne, buys all the stuff and loses interest. It's the guys that build that tend to stay in the hobby for a long time. My father built his first model airplane in 1929 and is still doing it. His first R/C plane was in 1938. I built my first model airplane (hand launched glider) in 1954 and first R/C airplane in 1962. Still going strong. Never quit even during a 30 year Navy career.
Seems like everyone today demands instant gratification and since it was so easy to start with lose interest in a hurry.
Old 01-31-2009, 08:14 PM
  #13714
Aparently he got intrested in quads and going to the Coast. He sold almost everything he had. At those prices he gave it away.
His loss is my gain.
Old 01-31-2009, 09:13 PM
  #13715
Hey everyone. I was tuning my 125 for a new prop size (17.x4w) and ran into a couple of things I hadn't seen before in my limited experience/reading and was hoping to see if these behaviors are is normal.
First, while setting the HSN, I did the typical slow leaning to top RPM. I got to 9300ish, but after 5-10 seconds the engine would slow to 8800ish. I watched it do this a couple times and it made me nervous about overheating. I backed it down to 9000, and it seems happy there. What does it mean when the RPM peaks, then slowly degrades?
Next, while stting the LSN, I again did the slow leaning until it died in transition, then backed it out 1/8 turn. The problem was the idle seems inconsistant and unreliable. I ended up turning it back out 1/2 turn before I could find a nice balance between decent idle and decent transition. I was wondering about this one because it was so far away from the "died during transition to WOT" position. Does that sound normal?
Now the part that may complicate things. Here's my setup:
1.25 with 17x4w APC/Tru-turn spinner
Perry VP30 Pump setup per instructions with the addition of an overflow line (no check valve)
Thanks for any insight you can provide!!
Pearhead : )
Old 01-31-2009, 09:18 PM
  #13716
My Feedback: (16)
w8ye's Avatar
sounding good pearhead. Everything sounds normal and typical
Old 01-31-2009, 10:00 PM
  #13717
I have to add a few oz's of weight to the front of my twist 150 saito 180 combo..I have already moved the 2000 mah battery under the tank.. I am wondering if any of you can recomend a weighted prop hub?
Old 01-31-2009, 10:12 PM
  #13718
My Feedback: (16)
w8ye's Avatar
Your threads are 8m X 1.25
Brass spinner nut
http://www3.towerhobbies.com/cgi-bin...?&I=LXL736&P=7
The lock nut
http://www3.towerhobbies.com/cgi-bin...?&I=LXL758&P=7
Old 01-31-2009, 10:17 PM
  #13719
mike early's Avatar
Or, if you want to use a spinner:
http://www3.towerhobbies.com/cgi-bin...?&I=LXK246&P=7
Old 01-31-2009, 11:01 PM
  #13720
Question regarding a Saito 125.
I am thinking of using a flexible muffler for the 125.
[link]http://www.horizonhobby.com/Products/Default.aspx?ProdId=SAI300T74B[/link]
The above 14mm pipe with fuel tank pressure tap is the only one I found. I really don’t want to cut up my cowl for the muffler so I was thinking of the flexible pipe. I read where securing it from flexing is important so fatigue does not crack it. Do you have any other pointers or experience with one of these you could share?
Al
Old 01-31-2009, 11:04 PM
  #13721
My Feedback: (16)
w8ye's Avatar
Your engine is 13mm not 14mm
The flex pipe reduces power a little
here's the only one they have and you have to use the muffler on the end if you want pressure
http://www.horizonhobby.com/Products...dID=SAI125A111
Old 01-31-2009, 11:18 PM
  #13722
mike early's Avatar
There's other options, like the turbo muffler. With or without the 90º fitting, depending on the cleanest install for your application.
http://www.rcuniverse.com/market/item.cfm?itemId=465588
edit: He might be out of stock on the 13mm versions currently
Old 01-31-2009, 11:19 PM
  #13723
ORIGINAL: w8ye
Thanks for the 13mm info and correct link. Now I guess I have to rethink this some.
Thanks again.
Old 01-31-2009, 11:44 PM
  #13724
My Feedback: (16)
w8ye's Avatar
google Central Hobbies and smell around some. http://www.centralhobbies.com/ they are in Billings
They sell Y-S and I think the Y-S 110 is 13mm
http://www.macspro.com/four_pre.asp#thread_index
Old 01-31-2009, 11:55 PM
  #13725
mike early's Avatar
None of the YS stuff has pressure fittings, though.
I have used this elbow. It's great.
http://www.centralhobbies.com/Exhaust/90radapt.html
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
