Welcome to Club SAITO !
Old 01-31-2009, 11:57 PM
  #13726
mike early's Avatar
Default RE: Welcome to Club SAITO !
They have the best price on Type F glow plugs I've seen in a while:
http://www.centralhobbies.com/glow/glowplug.html
Old 02-01-2009, 06:27 AM
  #13727
Rudolph Hart's Avatar
Hi pearhead,it's normal to worry yourself out of the perfect tune.Dave said the same thing a while back to me.A very liberal translation is..you're nearly there mate!
Old 02-01-2009, 08:35 AM
  #13728
My Feedback: (15)
rabbid fly's Avatar
Hi guys, what would be the best glow plug for a Saito 150 GK.
Thanks. Phil
Old 02-01-2009, 08:39 AM
  #13729
My Feedback: (16)
w8ye's Avatar
OS "F" from Tower
Saito "SS" from Horizon
Old 02-01-2009, 12:43 PM
  #13730
My Feedback: (23)
GaGeeBees's Avatar
Or an Enya #3 from Enya Metal Products
Old 02-01-2009, 01:11 PM
  #13731
My Feedback: (16)
w8ye's Avatar
Or the Y-S Four Stroke plug
Old 02-01-2009, 01:53 PM
  #13732
Can anyone tell me if a Saito 150 would suitable for a model weighing in at 17LBs or should i go for the 180, Iv heard the 180 really drinks fuel , thats my dilema.
Old 02-01-2009, 03:05 PM
  #13733
At 17 lbs if operating costs are of concern gas might be the better option.
Old 02-01-2009, 04:19 PM
  #13734
Its not the operating cost that concerns me its duration, 17lbs would need 26cc and gas does run longer for sure . Four strokes have more torque and rev higher so would a saito work well with 17lbs?
Old 02-01-2009, 05:20 PM
  #13735
mike early's Avatar
The best of both worlds is a Saito Gasoline 4-Stroke.
Old 02-01-2009, 05:22 PM
  #13736
Biggles,
I think the 1.50 would be under powered. I fly a 15 lb plane with a 1.80 and it is not over powered but flies well. If you want lots of snap and extra power move up from the 1.50.
Jim
Old 02-01-2009, 08:41 PM
  #13737
pilotpete2's Avatar
Oh would I love one of those[sm=cool.gif][sm=cool.gif]
Pete
Old 02-02-2009, 06:43 AM
  #13738
My Feedback: (14)
ORIGINAL: mike early
Here! Here! Or is that hear! Hear! ?
I'm glad that I bought mine when they were $650. It wasn't that long ago either.
I'm thinning out my gassers, but that one stays. At least for a while longer. Sure is purdy.
Ed Cregger
Old 02-02-2009, 08:00 AM
  #13739
Thanks RC , I will go down the 180 route , I think that will do what I want , I will just have to consider a bigger tank installation.
Old 02-02-2009, 07:54 PM
  #13740
I am selling a Saito 220 & 180 along with a saito 220 aluminum engine mount and a Tru Turn P-51 3" spinner. ALL FOR $500 OBO. These engines are in great running condition.
Old 02-03-2009, 12:29 PM
  #13741
Ed your talkin about that oh so sweet fg 36. I am thinking about this engine for a RC Guys Decathlon. Would you recomend this motor. What kind of plane did you slap yours into. Also are you running pump gas or (high octane is this even possible or will it harm the motor?) very interestered in HEAR HEARING from you.
Greg R.
Old 02-03-2009, 02:46 PM
  #13742
My Feedback: (14)
So far, Greg, the only running of the FG-36 that I have seen has been on You Tube. Health problems have kept me away from the garage test area and the flying field for a while. But, if you go to the You Tube site and click on videos, then type in FG-36, you can see several videos of this engine in action. I love the sound of it running and how low it idles.
After seeing the FG-36 powering a Hanger 9 Extra 260, I had to have one, so a sample of the Extra 260 is sitting NIB in the garage as I type.
Things have been improving somewhat over here lately, so I just might get this combo airborne this year. Take care.
Ed Cregger
Old 02-05-2009, 10:04 PM
  #13743
My Feedback: (40)
MinnSpin's Avatar
Hey - Thanks for inviting me!
I love Saitos - they are as dependable as a Remington clock with Swiss timings. My hanger includes 30, 56, 72, 91, 100, 125 - best running engines I have ever had. Say - I am in the market for a used 182 twin - and a used radial. I bought the 33% Sukhoi (Hanger 9) from a club member - he had a DA100 twin - I would like to power it with a radial - suggestions? Do you think Saito will make a Gas Radial? Wouldn't that be a kick in the pants!
Old 02-06-2009, 08:20 AM
  #13744
mike early's Avatar
I wonder which engines share the same valve cover gasket size.
I imagine there is at least some overlap.
I find myself buy new gasket sets only for the valve cover gasket.
It'd be nice if one could buy spare just Rocker Arm Cover gaskets, as they call them.
Any ideas?
Old 02-06-2009, 08:29 AM
  #13745
My Feedback: (16)
w8ye's Avatar
The Saito 45 MKII and "S" , 50,56,62,65,72,80,82,91,100,110,125,90T,100T,132T, 182T, 170R3,325R5 all use the same valve cover gaskets
Old 02-06-2009, 08:36 AM
  #13746
Need help! Just got back from a month vacation and when I tried to fly my bird (.56 saito inverted engine) it took me a while before I was able to start it, I did primed it first before cranking it. Plus it seemed to be stuttering and smoke coming from inside the cowl [] and took around 20 mins before it was running okay. Before I left I cleaned and put in lots of after run oil in the cylinder head and the carb. I did set it plane right side up (engine inverted) on the rack. Could this have caused it to make such funny sounds and hard starting?
Old 02-06-2009, 08:43 AM
  #13747
My Feedback: (16)
w8ye's Avatar
After run oil usually does not run very well in an engine
Old 02-06-2009, 08:46 AM
  #13748
mike early's Avatar
http://www.horizonhobby.com/Products...rodID=SAI82A32
Is the cheapest way to get a set of valve cover gaskets for my 91 and 125 it appears.
The blue ones seem to be a lot more durable than the brown ones used on the 125.
Saves me a buck fifty everytime I need to replace. But probably saves more because they are the durable blue ones.
Thanks!
Old 02-06-2009, 08:48 AM
  #13749
ORIGINAL: w8ye
Thanks w8ye, what do you normally use when you will not run your plane for like a month?
Old 02-06-2009, 09:34 AM
  #13750
My Feedback: (14)
The next time you get a new gasket, run it through your combo printer/scanner/fax machine first. Print it out and then adjust for correct size. After that it should be simple to save that $1.50. Me, I don't use valve cover gaskets unless the engine is pressurized or has an oil line feeding back to the intake manifold. I don't think you're stupid, so don't think that. Sometimes simple things just get by us when busy in every day life. If you don't have a scanner, I'm sure another club member might let you use his, or even do it for you.
Ed Cregger
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
