Welcome to Club SAITO !
Old 03-26-2010, 10:12 AM
  #17126
mk1spitfire
mk1spitfire's Avatar
Default RE: Welcome to Club SAITO !
Saito 82
Ive just got a new gasket set and theree is a metal Washer the same size as the two orings provided. both intake manifold pipe.
Where does this metal washer go,? is it a packer between the pipe and engine? how doesit fit?
Cheers?
Old 03-26-2010, 10:57 AM
  #17127
blw
blw's Avatar
The manual doesn't show it well, but the stackup is first a black rubber o ring into the engine manifold intake. This should be one made of viton and labelled separately from the other o ring. It should fit easily into the engine. Next is the shiny metal washer. When you put the manifold pipe into the intake, you will see how the shoulder on the manifold pipe pushes the metal washer into the engine for a good seal. Hope this is clear enough.
Another way to do it is to put that metal washer on your manifold pipe and then slowly work the pipe through that black washer and into the intake. The metal ring will fit naturally when you have it all the way in. Be careful to not nick the washer with the edge of the manifold.
Old 03-26-2010, 11:16 AM
  #17128
mk1spitfire
Thanks blw. I guessed it may be this way. Now Im unsure which bloody oring was the viton one as I it appears now I have been foolish to assume they are both the same!! Dam Oh well, its a 50/50 i guess the proof will be in the melting but at least the metal washer will hide that now!!!
Old 03-26-2010, 11:59 AM
  #17129
w8ye
My Feedback: (16)
w8ye's Avatar
The Viton O-ring lasts longer at the intake manifold - cylinder junction but a regular O-ring usually lasts a good while. Do not worry.
Old 03-26-2010, 09:41 PM
  #17130
charlie1960
I find these o-rings at my local napa auto parts store.
the viton o-rings are in the automotive AC parts
Old 03-26-2010, 10:08 PM
  #17131
Neil K
My Feedback: (8)
Hi Gents, I am in process of purchasing my first multi cylinder powerplant, A Saito 270T. And figured this would be the best thread in the universe for information and ideas. And also would like to join club Saito if I may. Looking forward to the great exchange of ideas, thoughts and theories with you all.
Neil Kilchriste
Waco Brother # 142
Old 03-26-2010, 10:19 PM
  #17132
davidgeorge212
davidgeorge212's Avatar
has anyone heard anything more about the gold plated saito 30's. Its been a little while now since they stopped taking orders.
Old 03-27-2010, 04:33 AM
  #17133
GaGeeBees
My Feedback: (23)
GaGeeBees's Avatar
ORIGINAL: Neil K
Neil Kilchriste
Waco Brother # 142
The 2.70 twin is a fine engine and a favorite of mine. I've got three of them mounted on airplanes and all run great. I use McDaniel/SonicTronics glow drivers. There's no engine out there that's easier to start; just prime, turn on the glow power and it's one flip backward against compression and they're off.
Old 03-27-2010, 03:03 PM
  #17134
GarySS
My Feedback: (13)
What is the recommended fuel tank size for a Saito 1.50 (will go into a Cermark Pitts, 15% nitro, somewhat hard sport aerobatic flying). I noticed Wm Robinson's rule is 1 oz per CI/ minute. What is the general consensus? Thanks/////////
Old 03-27-2010, 07:01 PM
  #17135
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Gary, Bill's numbers are right on providing the low speed needle is set correctly. Twenty oz should give you a good 10 minute and more than enough to land and even blow a couple of landings.
Old 03-27-2010, 07:04 PM
  #17136
Neil K
My Feedback: (8)
ORIGINAL: GaGeeBees
ORIGINAL: Neil K
Neil Kilchriste
Waco Brother # 142
Thanks GAGEEBEES, Any help or knowledge will help immensly, Thanks Again, Neil
Old 03-27-2010, 09:26 PM
  #17137
GaGeeBees
My Feedback: (23)
GaGeeBees's Avatar
ORIGINAL: Neil K
ORIGINAL: GaGeeBees
ORIGINAL: Neil K
Neil Kilchriste
Waco Brother # 142
Let me know what questions you may have. Also, let me know if you need a manual. I've got a scan that I can upload or email you. You're really gonna like this engine. Thanks - Paul
Old 03-28-2010, 06:24 PM
  #17138
tbone4343
need saito parts is noel still around
Old 03-28-2010, 07:48 PM
  #17139
w8ye
My Feedback: (16)
w8ye's Avatar
Noel Jensen
204 S Division St,
Whitehall, MT 59759
406 287 3270
[email protected]
John Sepe
Seco Enterprises
301 Sabal Ridge Circle, Ste A
Palm Beach Gardens, FL 33418
ph. (561) 625-9671
Email at [email protected]
http://www.bj-model-engines.com/
B.J.’s Model Engine Service
A trade name of Flight Star Devices, Inc. Bill Jensen
51 Hillside Dr. Phone & Fax: 203-888-4819
Beacon Falls, CT 06403 Email: B.J.’s Model Engine Service
Old 03-29-2010, 07:10 PM
  #17140
kochj
For those interested in a NEW saito....
Being that this is a Saito Club (figured you all would be)
Advantage hobby hase a HUGE sale on ALL saito's...
Some more discounted more than others....
The final four days has a nother 10% off the already discounted price....
Picked up the engine I ALWAYS wanted...
Saito radial 5-cyl.
for 1420$....Delivered!!!!!
You all realize the normal price is 2000$ plus shipping...
..................Yeah....
Old 03-29-2010, 07:15 PM
  #17141
Neil K
My Feedback: (8)
How do I join up with the BROTHERHOOD of all the Saito lovers out there???? Is there a #????
Neil Kilchriste
Waco Brother # 142
Old 03-29-2010, 07:27 PM
  #17142
kochj
I don't think that it is a science.....
Pick your favorite number... and do a dance by, spining around
And repeating the words " I will give my engines to Justin"
"I will give my engines to Justin"!.....
You keep saying this until you are delirious, and you send me a PM and I give you my
Shipping address!
Old 03-29-2010, 07:33 PM
  #17143
Crash-RCU
I have a Saito 91 and very limited ground clearence, has any one used a APC 12X9 prop or should I use a 12X8. With a 12" prop I will have a hair over 1" ground clearence with trike gear so I really need to stay with the 12" prop.,
Old 03-29-2010, 07:39 PM
  #17144
GaGeeBees
My Feedback: (23)
GaGeeBees's Avatar
ORIGINAL: Crash-RCU
I have a Saito 91 and very limited ground clearence, has any one used a APC 12X9 prop or should I use a 12X8. With a 12'' prop I will have a hair over 1'' ground clearence with trike gear so I really need to stay with the 12'' prop.,
I think you need to look at 3-blade or even 4-blade props if you have to stick with 12" diameter.
  #17145
w8ye
My Feedback: (16)
w8ye's Avatar
12 X 9 would be better
Old 03-29-2010, 07:40 PM
  #17146
kochj
ORIGINAL: Neil K
Neil Kilchriste
Waco Brother # 142
Here is a nice vid of a 300twin...
sounds great...
http://www.youtube.com/watch?v=szGiNSOc3rE
Is you 270T a twin carb?
Old 03-29-2010, 07:45 PM
  #17147
GaGeeBees
My Feedback: (23)
GaGeeBees's Avatar
ORIGINAL: kochj
ORIGINAL: Neil K
Neil Kilchriste
Waco Brother # 142
sounds great...
Here's one of my 2.70's running. The 2.70T is a single carb.
http://www.rcuvideos.com/video/Space...Engine-Run-wmv
Old 03-29-2010, 07:46 PM
  #17148
Tarasdad
Tarasdad's Avatar
ORIGINAL: kochj
Dangit, if I'd seen this last week Imight have a new Saito in hand. Been wanting a .56 or .62 size.
Old 03-29-2010, 08:19 PM
  #17149
NM2K
My Feedback: (14)
ORIGINAL: Crash-RCU
The 12x8 or the 12x9 will be fine, but be sure to get it idling low enough, or being able to land might be a bit of a challenge. 8>)
Ed Cregger
Old 03-29-2010, 08:22 PM
  #17150
Neil K
My Feedback: (8)
ORIGINAL: kochj
And repeating the words '' I will give my engines to Justin''
''I will give my engines to Justin''!.....
Shipping address!
No THAT is FUNNY, I like this outfit already lol Neil K
