Welcome to Club SAITO !
Old 03-29-2010, 08:25 PM
  #17151
My Feedback: (8)
Default RE: Welcome to Club SAITO !
ORIGINAL: kochj
ORIGINAL: Neil K
Hi Gents, I am in process of purchasing my first multi cylinder powerplant, A Saito 270T. And figured this would be the best thread in the universe for information and ideas. And also would like to join club Saito if I may. Looking forward to the great exchange of ideas, thoughts and theories with you all.
Neil Kilchriste
Waco Brother # 142
Here is a nice vid of a 300twin...
sounds great...
http://www.youtube.com/watch?v=szGiNSOc3rE
Is you 270T a twin carb?
Its the single carb version, supposedly 8 flights on it, and IS in beautiful well kept shape, N
Old 03-29-2010, 08:44 PM
  #17152
My Feedback: (8)
ORIGINAL: GaGeeBees
ORIGINAL: kochj
ORIGINAL: Neil K
Neil Kilchriste
Waco Brother # 142
sounds great...
Here's one of my 2.70's running. The 2.70T is a single carb.
http://www.rcuvideos.com/video/Space...Engine-Run-wmv
WOW GaGeeBee, That 270 in the Spacewalker sound great. Cant stop listening to it lol. the 300 sounds pretty doggone sweet too. The question from the gentleman earlier about tank size has me now wondering. Whats the average burn rate per minute in the 270T? Being my first multi cylinder im completely at a loss. Also Is the McDanials glow igniter the best hook up out there ? and at the risk of showing my ignorance, is it fiesable to run an ignition with glow fuel or will it even work? They Sure Sound Sweet though. Sorry if the questions are obviously that of a RANK newbie to multi 4S, if I keep that up I will never get a number lmao...Neil
Old 03-29-2010, 09:14 PM
  #17153
reyn3545's Avatar
Neil... you putting that motor on a Waco?
Old 03-29-2010, 09:22 PM
  #17154
My Feedback: (8)
No, Im putting it in a New (Old Stock) Byron Originals Pitts Special. One of the 80's kits I came acrossed awhile back. (BTY) I am searching desperately for an assembly manual for the Byron Pitts as the kit was complete minus the manual. I have tried contacting Iron Bay and they are just hopeless so, my quest for the manual shall continue. Also plan to use it ( 270T)in an old kit I have yet to build from Ace R/C the old 1/3rd Scale WEEKS Special. I believe it is a Miles Reed design should be plenty for it as it comes in with about the same weight as the Pitts 15-17 lbs and only calls for 30cc and up and I believe the 270 is just under 50cc if Im not mistaken (45cc- 48)
Old 03-29-2010, 09:24 PM
  #17155
My Feedback: (8)
On my 1/5th Waco im running an OS 120 surpass, it pulls her nicely.
Neil K
Waco Brother # 142
Old 03-29-2010, 09:39 PM
  #17156
swixtt's Avatar
Hi Guys
got a question and a few pics here of my Saito 100. i needed to have a look at this engine before i fired it up for the year. here is what i've found. can this be caused by worn main bearing? or what else would cause it?
ID:	1407604   Click image for larger version
ID:	1407605   Click image for larger version
Old 03-29-2010, 10:42 PM
  #17157
My Feedback: (16)
w8ye's Avatar
ORIGINAL: swixtt
Hi Guys
Yes
Old 03-29-2010, 10:52 PM
  #17158
My Feedback: (15)
frets24's Avatar
Neil,
You'll get a number soon, just have to wait until "blw" sees your request, then he'll log your #. I suspect you'll be #683 as greybeard aviation got 682 in post #16815.
Swixtt,
Looks like either a worn bearing allowed the rod to contact the case at the bottom of the power stroke or a piece of the bearing cage chipped off and got between the rod and case for a revolution or three. Were there any bits of debris inside the case? Might be a good idea to pop the crankshaft out and see if there's anything up front debris or damage-wise.
Old 03-29-2010, 11:08 PM
  #17159
swixtt's Avatar
thx guys. didn't see any metal in there. bearing doesn't feel right though.
need to source that now.
Old 03-29-2010, 11:25 PM
  #17160
My Feedback: (8)
ORIGINAL: frets24
Neil,
You'll get a number soon, just have to wait until ''blw'' sees your request, then he'll log your #. I suspect you'll be #683 as greybeard aviation got 682 in post #16815.
Swixtt,
Thanks for the information Frets 24. BTW what fretted instrument might you play? Myself? Guitar- 38 years worth relentlessly...and still cant play lol
Old 03-30-2010, 03:07 AM
  #17161
My Feedback: (15)
frets24's Avatar
ORIGINAL: Neil K
[Thanks for the information Frets 24. BTW what fretted instrument might you play? Myself? Guitar- 38 years worth relentlessly...and still cant play lol
Started off with piano, then graduated from guitar to every stringed instrument I could hold onto for a few days or more, except the harp. Fiddled and banjoed in a few country bar bands and played bass and guitar in a few more along with several bar rock bands all over the Ohio through N. GA circuit till '93. Been playing @ 38 yrs as well...and my kid at 16, playing for a year and a half, is better already than I ever was. Moniker came from the longstanding desire to get an extended neck (24 vs 22 frets) rickenbacker hollow body ala Tom Petty circa 1982, when I had to pick an email tag with the advent of internet, it seemed logical. Now self-employed for 11 years+, it just means I worry all day And if I keep buying Saito's I'll never get that ricky 24!
Old 03-30-2010, 04:19 AM
  #17162
My Feedback: (23)
GaGeeBees's Avatar
ORIGINAL: Neil K
1 ounce per cubic inch per minute at wide open throttle is a very good rule of thumb. I've got a 28 ounce tank so that gives me a solid 10 minutes+ of run time at wide open throttle. The McDaniel is a very good onboard glow and is the one I use most often. They have great service and support. I usually buy the battery pack from them as well, that way I know the wiring is heavy enough for the amperage draw and all the plugs match up and it's basically plug-n-play. Regarding ignition - yes it can be done and I had a 2.70 with a C-H ignition setup. Mine had an actual mechanical spark advance and the whole nine yards. Pretty complicated but it worked. I converted it back to glow plugs for the sake of simplicity.
Old 03-30-2010, 07:49 AM
  #17163
Rudolph Hart's Avatar
Nice photography re focus on the main cause for concern,have you looked at your pix?
Old 03-30-2010, 08:52 AM
  #17164
swixtt's Avatar
what you mean boy?
Old 03-30-2010, 09:49 AM
  #17165
blw
blw's Avatar
Neil K- you are indeed member #684. Good to have you hanging around....
Old 03-30-2010, 03:30 PM
  #17166
mk1spitfire's Avatar
Can you back flip start an 82?
Old 03-30-2010, 03:43 PM
  #17167
My Feedback: (8)
I cant seem to quit watching that video lmao. Mine will be mounted up soon and ready to run, I'll probably wind up wearing it out on the back porch
Neil K
Saito # 684
Waco Brother # 142
Old 03-30-2010, 04:49 PM
  #17168
My Feedback: (15)
CAPT John's Avatar
I have a question for you guys. I have a well broken in Saito 150 that has been a real trooper for the past couple of years. Recently I started having a problem with the engine at high throttle. It seems to load up and gradually drop RPM until it quits (fortunately my Super Stearman has survived the dead stick landings). The engine starts easily and peaks at about 8500 rpm with a 16x8 Master Airscrew Classic Series prop. After I richen the engine about 400 RPM, the RPM gradually decays until it dies around 6500 RPM. I thought it was too rich, but as I try to lean the engine it quickly becomes too lean and dies. If I try richening the high end more than about two turns out from closed, it loads up and dies. I have changed fuel tanks, all fuel tubing and the glow plug with no improvement. I also tried leaning the low end, but no luck. Any ideas of what I'm missing (besides good engine tuning skills)? Thanks in advance for any help!
John
Old 03-30-2010, 08:17 PM
  #17169
My Feedback: (34)
Custom Nexstar, Flat Wing, Converted to a Tail Dragger and My First Try At Applying Monokote, With a SAITO56Golden Knight Nice Look
Got 2nd Place at out Swap Shop and Show
ID:	1408137   Click image for larger version
ID:	1408138   Click image for larger version
ID:	1408139   Click image for larger version
Old 03-30-2010, 09:09 PM
  #17170
reyn3545's Avatar
If that's your first try... you've been missing your calling in life! Looks great... good luck with it.
Old 03-30-2010, 09:35 PM
  #17171
My Feedback: (34)
Thank you very much, it was the first time and cannot wait to do another one.
i have a few ideals.
Old 03-30-2010, 09:41 PM
  #17172
My Feedback: (18)
retransit's Avatar
Where's the Saito stickers?
Old 03-30-2010, 11:26 PM
  #17173
swixtt's Avatar
who the h got 1st!
Old 03-31-2010, 05:24 AM
  #17174
Poheller,
Very nice work! A job like that deserves another prize. Drop me a PM to discuss it.
Jim
Old 03-31-2010, 06:00 AM
  #17175
My Feedback: (34)
The Saito Stickers are up front on the left and right side of the Engine, it's the little sliverones that came with it i have to find some nicer ones.
PO
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
