Welcome to Club SAITO !
Old 08-31-2010, 07:40 AM
  #18426
Default RE: Welcome to Club SAITO !
ORIGINAL: Tarasdad
Pressing and pulling is how bearings on high-performance motorcycle engines are replaced. Been there, done that too many times (used to be a motorcycle mechanic).
On my Saito 180, there is no lip to catch at the inside of the main bearing. I tried oven heat and the wood board smack at temps up to 300 degree C, without it moving.
I then used a expansion bolt normally used for anchoring bolts in concrete, It is a stud and nut combination with a tapered sleeve that expands when the bolt is tightened. I picked the one closest to the ID of the bearing, inserted it in the bearing and tightened the bolt until it expanded into the inner race. I heated the crankcase with a heat gun and then used an puller on thr bolt to pull the bearing.
Regards,
Richard
Old 08-31-2010, 09:15 AM
  #18427
Thanks for your replies...I will be ordering Zinger props today.
fa100 - 13x6
os125 - 14x6
Brian.
Old 08-31-2010, 11:24 AM
  #18428
My Feedback: (14)
ORIGINAL: blw
An argument could be made that the one bladed prop is one of the most inefficient......
Yes, it could be made, but it would be wrong.
Ever see the control line speed planes that flew with one bladed props?
Ed Cregger
Old 08-31-2010, 02:57 PM
  #18429
My Feedback: (16)
w8ye's Avatar
Some contest free flight models also had one bladed props
Old 08-31-2010, 04:32 PM
  #18430
Any idea for a fuel tank size for a Saito 300 twin single carb single plug? I'm thinking about 8-10 minutes flights.. I searched the forum first to no avail.
Old 08-31-2010, 05:07 PM
  #18431
blw
blw's Avatar
ORIGINAL: NM2K
Ed Cregger
I was referring to drag and weight. Also, the amount of air it will pump past the prop vs two & three blades. Yes, I know about c/l engines that turned mega-thousands rpm. (Those are interesting too)
Old 08-31-2010, 05:12 PM
  #18432
JohnB96041's Avatar
BobH: I use a 16oz tank on my Christen Eagle II with the Saito 3.00 twin. I get about 10-12 minutes of flight and still have a little in the tank when back on the ground. This plane weighs about 16 lbs.
Old 08-31-2010, 08:17 PM
  #18433
John, thank you for that information ..
Old 08-31-2010, 08:52 PM
  #18434
JohnB96041's Avatar
I love the sound of the Saito 3.00 twin. I do have an onboard glow driver that kicks in at just 1 click under half throttle. However, I have found that the Christen Eagle II is really touchy on takeoff. Once in the air it flys great. However, my favorite airplane is either the Spacewalker 120 (Saito 1.80) of any of my four Funtanas with Saito 1.25's. Hope you enjoy the 3.00 twin, I do.
Old 08-31-2010, 09:23 PM
  #18435
John which on board glow are you using? I have used a few myself. I just lost my CE this past weekend. It was flying with a 3.2 taurus engine. A friend built the plane (bought it from him actually) the battery tray came off in flight and I lost the radio.. hence the plane. My CE was pretty easy to take off and land.. I didn't have any problems with it.
Old 08-31-2010, 10:47 PM
  #18436
JohnB96041's Avatar
BobH: I use the Sullivan Glow Driver (Single and Twin).
Old 08-31-2010, 10:50 PM
  #18437
JohnB96041's Avatar
I lost my first Funtana S90 last summer with the same thing, threw the battery out doing a vertical snap. Was lucky and got an S90 off ebay. Finished it and have it ready to fly. Will try to rebuild the broken S90 this winter. I also fly the x100 and 2 of the new 125's. Love all of them.
Old 08-31-2010, 11:10 PM
  #18438
John thank You again. I have a sullivan single. I can get a double easy..
I think it was during spins the the battery tray came lose.. I have a NIB CE.. so if i want another i can build it.. if not i'll just sell it.
Old 09-10-2010, 04:00 PM
  #18439
I have just received a Saito 90TS Flat Twin AAC, LL, it has a single bright valve cover on each cylinder that covers both rocker arms, and there is one carbureter with one intake and one set of needle valves, however, the picture on the box it came in and the picture on the instruction manual shows a duel carbureter and seperate valve covers on the cylinder heads, I am confused ???
Old 09-10-2010, 04:33 PM
  #18440
JohnB96041's Avatar
Show a picture of the engine.
Old 09-10-2010, 08:31 PM
  #18441
My Feedback: (16)
w8ye's Avatar
The picture on the box is of a 90T or 100T. You have a 90TS which is completely different.
The 90TS is a very nice sweet running engine
Old 09-11-2010, 01:54 AM
  #18442
Kostas1's Avatar
Guys,
do you know if someone in UK
sells the official prop nuts and prop washer for the Saito FA-150 ?
Old 09-11-2010, 07:00 AM
  #18443
My Feedback: (16)
w8ye's Avatar
ORIGINAL: Kostas1
Guys,
http://www.macgregor.co.uk/saito.htm
Old 09-11-2010, 01:15 PM
  #18444
Yes it is a nice engine BUT I NEED THE MANUAL! The one they sent is for a twin with dual carbureter, I copied the one off the Saito website for a 90TS and it is also for a dual carbureter twin, where can I get the correct manusl for my engine?
Old 09-11-2010, 04:48 PM
  #18445
JohnB96041's Avatar
Sparky71: Here is the link http://www.horizonhobby.com/ProdInfo...oke_Manual.pdf.
Notice the front cover of the manual. It covers the following engines: FA60T, FA90TS, FA100T, FA182TD, FA-300TL, FA-300 TTDP.
Old 09-11-2010, 07:15 PM
  #18446
n6iap's Avatar
Here is a question for those with a 4 cycle gas Saito.
I have an FG-20 that has successfully flown about 15 flights in the 120 size Aeroworks Yak54. I am still using the 15x6 break-in prop and getting 9000-9500 rpm on the ground. When I put the airplane in the air it runs great up to ¾ throttle. Responses, transition and idle are all good, but at full throttle it cuts out in flight; not on the ground. This has not been an issue other than make me nervous that it is going to dead stick and that I don’t have all the power I could have. If this is normal until I get past the 20 flights and go with a bigger prop that’s okay I just don’t want to damage something. The ¾ power gives me plenty of power for sport flying but if it is supposed to go faster, why not?
Old 09-11-2010, 07:36 PM
  #18447
My Feedback: (16)
w8ye's Avatar
You may have a bad ignition system?
I would go ahead and stick a 16 X 6 prop on it.
Old 09-11-2010, 07:37 PM
  #18448
My Feedback: (16)
w8ye's Avatar
Old 09-12-2010, 06:52 AM
  #18449
Rudolph Hart's Avatar
It sounds like the engine is running to hot for some reason
Old 09-15-2010, 06:27 PM
  #18450
mike early's Avatar
I cannot find the new style saito right-angle exhaust adapters. anyone have a link?
Edit: Found it...
http://www.horizonhobby.com/Products...rodID=SAI65163
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
