Welcome to Club SAITO !
Old 12-09-2010, 07:35 PM
  #19201
My Feedback: (139)
Default RE: Welcome to Club SAITO !
Ok I have 2 saito 30's nib , i can't for the life of me find a plane to put them on! I'll go for any plane that's scale or sport flying, someone please give me a recommendation , thank you!
Old 12-09-2010, 08:00 PM
  #19202
JohnB96041's Avatar
Solarviper: two suggestions come to mind. First the Sig Seniorita, second the Somethin Extra.
Old 12-09-2010, 08:01 PM
  #19203
JohnB96041's Avatar
Even the LT25 would be a great little airplane for the Saito 30.
Old 12-10-2010, 12:08 AM
  #19204
My Feedback: (16)
w8ye's Avatar
Some of the 25E electric planes are good candidates for the Saito 30. Some of them are scale
Even the combat planes like the Mustang, Spitfire, and Corsair are good candidates. Hand launch and belly land. Fly in the weeds
Old 12-10-2010, 12:23 AM
  #19205
mike109's Avatar
G'day
I have a Saito 30. At the current time it is in a Dynaflyte Butterfly (large powered glider) and it powers that very well. I have also plans to put it in a Sig Kadet Seniorita or LT-25 but at the moment, Sig does not have any kits available.
The Phoenix Rainbow electric has been converted by a bloke that hangs around here. He loves it. I have the electric version and it is a very nice plane to fly. I considered putting the Saito in it but I crashed it (again) before I managed to do it. (My fault. I did not put the 2.4 gig antenna on the radio and you can guess the rest. The damage was very light though and I could easily get it flying again.)
Old 12-10-2010, 12:33 AM
  #19206
My Feedback: (139)
ORIGINAL: JohnB96041
i have the somthin extra, it wont fit
Old 12-10-2010, 12:35 AM
  #19207
My Feedback: (139)
I'm really thinking about putting one saito 30 in a E-flite piper Pawnee electric, what do you guys think?
Old 12-10-2010, 12:39 AM
  #19208
My Feedback: (16)
w8ye's Avatar
The GP Electro Stick is a good candidate to fill in and with a thin sheet of plywood over the firewall
http://www3.towerhobbies.com/cgi-bin...LXUTN8&P=7
Old 12-10-2010, 01:32 AM
  #19209
mike109's Avatar
G'day
I have just built my 8th Kadet Senior. All the others to date have been built as per the plan. No ailerons. This one has ailerons. I copied from an ARF Kadet Senior I have.
I built the wing the usual way (ie without ailerons but before joining the halves I cut barn door ailerons into the wing. Each aileron is 7 wing bays long and approx 85mm wide.
I drew a string line at the 85mm mark and then used a square to mark two vertical lines on the ribs 21mm apart. Then I cut out the 21 mm section of wing ribs and fitted two strips of 10mm balsa to form the leading edge of the aileron and the trailing edge of the wing. I also fabricated the ends of the ailerons from 5mm balsa and then cut the trailing edge to let the ailerons out of the wing.
I reduced the dihedral to about half the original amount. The ARF has about 1/4 the normal "no aileron wing" dihedral.
I also fitted sheeting between the wing ribs in the centre bays (I have done this on all my Kadets) and later I glassed the centre with 3.4 oz cloth and Sig resin.
It flies well. It is less stable than the standard version but more stable than the ARF. It can be flown with rudder and elevator only or it can also do normal aileron turns quite neatly. It also rolls better than I thought it would.
Noise is provided by a Saito 72 which is total overkill and part of the reason I strengthened the wing centre section. Apart from that the plane is stock standard.
I covered the sheeted part at the front with Solatex and the rest with film.
Have fun building your aileron wing.
PS I call the plane "Scraps" because it was built from a wing kit, a fuse kit, some balsa and any covering I could find.
Mike in Dubbo.
ID:	1532445   Click image for larger version
Old 12-10-2010, 04:58 AM
  #19210
JohnB96041's Avatar
I started with the Saito 30 on my Somethin Extra and finally graduated to the Saito 82a. The 30 made it a nice trainer, the 82a made it a rocket.
Old 12-10-2010, 12:52 PM
  #19211
My Feedback: (20)
Vertical3-D's Avatar
It's been awhile but I just wanted to say thanks to those that helped with my 130T, it's now running beautifily, drops a cyclinder once in awhile but it always pics back up with a few quick blips on the throttle...heres a couple pics on my GP 81" Cub turned tundra cub with the 6" balloon tires and flaperons, will be flying on skis when we get some snow this year...
ID:	1532568   Click image for larger version
ID:	1532569   Click image for larger version
Old 12-10-2010, 03:55 PM
  #19212
My Feedback: (20)
Broken Wings's Avatar
Who's going to be the first to mount one of the Saito 170 radials to a 1/4 scale Piper Cub?
The 90 size would probably work real well in the GP ARF Cub. I've got one and its a real nice model.....
http://www.flickr.com/photos/vzlet/5...5428/lightbox/
Apparently its a J-4P variant.
ID:	1532641   Click image for larger version
ID:	1532642   Click image for larger version
Old 12-10-2010, 05:15 PM
  #19213
My Feedback: (139)
ORIGINAL: w8ye
http://www3.towerhobbies.com/cgi-bin...?&I=LXUTN8&P=7
Thats nice! I think you just showed me my 2nd airplane for the other saito 30, thanks
Old 12-10-2010, 06:22 PM
  #19214
My Feedback: (16)
w8ye's Avatar
The Cub is a J3P variation
The J4 was a side by side J3
Old 12-10-2010, 07:42 PM
  #19215
My Feedback: (24)
Kmot's Avatar
Wow, that radial engined Cub is so awesome! It even has a collector ring exhaust. Fantastic! [sm=thumbup.gif]
Old 12-11-2010, 04:10 AM
  #19216
Rudolph Hart's Avatar
Agree with all the above comments,awesome job brokenwings bet it sounds and flies great,good detail thanks for that mate
Old 12-11-2010, 07:08 AM
  #19217
My Feedback: (139)
OK what size tank should i use on my piper Pawnee with the saito 30, i have a 2,4, & 6 oz tank, i would like to get at-least 10-12 mins out of one tank minimum
Old 12-11-2010, 07:18 AM
  #19218
My Feedback: (16)
w8ye's Avatar
It takes a 6 oz for the 30
Old 12-11-2010, 12:52 PM
  #19219
Mike,
I am building my SIG Senior as a test bed and also so my old mate up here in FNQ can use it to get his Bronze wings. He is building a Mick Reeves Sopwith 11/2 Strutter and an Arizona Models Avro 504 (when he gets the rest of the bits) and a small electric FE 8 (plan from scale models) so it is up to me to provide the training ships etc. I am doing the original build right down to aeroflyte balsa cement, interestin trip
Now re your engine I have seen one with an OS 91 up from and one with alternately a Saito 65 and a OS 61 al of which performed well. They were used as training a/c and also as glider tow a/c which they also dod well. The one with the alternate engines had a removeable firewall and I'll post photos of this when I get mine finished. This idea harks back to the O/T days (actually hen O/T was modern flying late 1930's and 1940's) where engines where changed for the different classes of LER or "speed" (duration) events where whole engines and firewalls were removed from one model and exchanged for different classes of engine.
Thanks for your data on te aileron fit out saves me working it all out (much appreciated
You had better start getting a couple of O/T models organised for Easter and come to Paul Farthings for te NSW SAM Champs at Canowindra.
Trust you are enjoying the wet and didn't get to affected by the floods.
Old 12-12-2010, 02:44 PM
  #19220
My Feedback: (20)
if I had more money the 90R3 woulda been on my Cub instead of the twin but I like the 130...feels real "vintage" and is more than enough power for the plane, and despite the weight if you drop the flaperons it's almost hard to get it to land in a short distance, you have to just about stall it...
Old 12-14-2010, 04:32 AM
  #19221
Hello guys and just a quick note of surrender from down under,please please can one of our american flying buddies chip in so we can buy oprah a ticket?
Old 12-14-2010, 07:25 AM
  #19222
ORIGINAL: Old Fart
Where do you want to send her?
Regards, Richard
Old 12-14-2010, 07:44 AM
  #19223
JohnB96041's Avatar
Old Fart: We did buy her a ticket. That is why she is there.....Ha. And it was a one-way ticket at that.
Old 12-15-2010, 02:36 PM
  #19224
Re Oprah one good thing our Prime Minister had tryouts for her new job "being Oprah's front person" not that I am biased.  Now to business has any one made and used successfully a prop shaft extension for Saito in the 91 to 125 range.  I want to bury my engine for the Reliant inside the cowl but unless I can devise / use a prop shat extension this is not possible, any thoughts / ideas greatfully accepted
Old 12-16-2010, 04:10 AM
  #19225
I'll bet a carton of vb that when she farts it sounds like a well tuned small block saito getting quickly throttled up.The prop shaft extension is interesting to me too.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
