Saito 72 carb
Old 11-22-2005, 11:10 AM
minan59
Default Saito 72 carb
This maybe a dumb question please bear with me.I want to mount a Saito 72 horizontally. I would prefer to remove the carb and reinstall it 180 degrees from its original placement. This would place the needle valve up on top with easier access. It looks like there are 2 screws to remove , flip the carb over and reinstall the screws. Is the any reason I shouldn't do this? I've done it with 2 stroke motors but this is my first 4 stoke. Mike
Old 11-22-2005, 11:45 AM
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Default RE: Saito 72 carb
Go for it, I have most of mine that way.
Old 11-22-2005, 05:11 PM
daveopam
My Feedback: (9)
daveopam's Avatar
I do all of mine that way. i like the high speed needle opposite of the muffler.
David
Old 11-22-2005, 05:32 PM
w8ye
My Feedback: (16)
w8ye's Avatar
The Saito 72 has a problem with leaking at the manifold to head joint. While you are moving the carb would be a good time to put a little silicone around the manifold pipe's outside gasket area before you stick it back in the hole. Don't get any silicone inside the pipe.
Also, while you have the carb out of the way, is a good time to snug up the backplate retaining bolts.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
