OS engines users Club
Old 08-26-2015, 03:53 PM
  #601
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Thanks H man,The prop pictured on the 1.20 is a 15x7 three blade, that should be close to a 15x8 two blade. The care package we discussed is on its way, enjoy.
I rigged up the throttle today using my swing lever rig, it's slick and smooth operating. The servo is 537 bushing JR, I may swap it for BB one.
Old 08-26-2015, 04:30 PM
  #602
hsukaria
Thanks FDF. Just not experienced enough to "feel" the difference between a bushing and BB servo on throttle. Would that be noticeable? Or is it more for long term durability?
Old 08-26-2015, 04:46 PM
  #603
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
My biggest complaint is that this particular servo is noisy and doesn't center very well. To me quiet equals quality. I have an old ACE Data Master to test servos, it also has an inline milliamper meter, the digital servos are battery hogs, I like the three pole, (Armature) HiTechs, they hold center very well and are easy on the battery.
Old 08-27-2015, 06:17 AM
  #604
NWCORSAIR
My Feedback: (8)
Default os 120 pump issues
I have a os fs 120 pump and have a problem. It starts fine, runs fine, and then after a few minutes running will drop back to idle, no throttle control. Any suggestions.
Old 08-27-2015, 09:15 AM
  #605
NM2K
My Feedback: (14)
I agree. a 14x7 three blade prop is way too large, regardless of what the engine manufacture states, unless the engine is being sold as a "stroker", Don't mind me and my wacky Toshiba coffee soaked keyboard!
Ed Cregger, NM2K
Old 08-31-2015, 06:28 AM
  #606
Bax
You may have a problem with the pump/regulator system, especially if it's a few years old and has been run infrequently.
Old 08-31-2015, 07:30 AM
  #607
NWCORSAIR
My Feedback: (8)
What is the fix?
Old 09-01-2015, 07:13 AM
  #608
Bax
Try running it for several tanks' worth of fuel to see if the pump/regulator system needs to loosened up. They can get dry and not regulate properly. The only other solution is to replace the carb/regulator assembly. If it's bad, you'll likely have to locate something online. The pumps and carbs for the FS-120 Surpass I and II are no longer available from O.S., but might be found through an internet search. Neither of those two engines are supported by O.S. any more.
Old 09-03-2015, 09:43 AM
  #609
Sport_Pilot
Sport_Pilot's Avatar
Bax, What is the material used on them? I believe some have repaired similar regulators no longer supported by cutting the right material to shape and gluing a small metal plate where the spring or valve rests against it. Also cutting down a larger one made for some other regulator or pump.
Old 09-04-2015, 04:33 AM
  #610
Bax
We have no idea what the material is. We never disassembled the pumps, since they were not repairable by anyone other than the factory. Some pumps could not be disassembled without destroying them.
Old 09-06-2015, 03:50 AM
  #611
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
When I installed the new Boca Bearings in the OS 1.20 Surpass I did not remove any of the seals/shields. I had a change of heart and disassembled the engine and removed the rear most seal/shield, now he vent gurgles as it should when the engine is rotated. It acted like the crankcase vent was blocked with both seals in place. I got it timed correctly both times.
Name:	OS 1.20FS II.JPG
ID:	2118269   Click image for larger version
Name:	OS 1.20 on Ultra Stick.JPG
Old 02-22-2016, 11:02 AM
  #612
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Alpha .56 sorted out. I had struggled some with a new OS .56 Alpha with the engine surging and almost quitting. I got busy and let it sit in the box a while and decided to see what I could do with it today. When I put it in the box I had pulled the high speed needle out for safe keeping. Today I happened to look in the needle socket and saw two pieces of black dirt, one big and one little. The little one was in the metering hole, the larger right beside the metering as if drawn there by the fuel flow. I flushed the metering hole with PB Blaster, (with the carb off the engine), it was handy. The reults.
OS .56 Alpha
Prop==Bolly 12.5x6
Fuel==WildCat 10% with 18% full synthetic
Plug==Fox Miracle
Exhaust=Stock
Max rpm=10,380, rock steady
Idle======2,000
Excellent engine
Name:	O)S .56-1.JPG
Old 10-07-2016, 12:18 PM
  #613
szempruw
I'm rebuilding 2 older OS MAX .50 FSR engines and I can't find piston rings. Frank Bowman no longer making them. I have email into Caber Engineering in Italy. Original part number is 25103405. Anybody have any ideas where to get?
Old 10-12-2016, 05:38 AM
  #614
SuperNash
Try this guy, I don't see a 50FSR ring listed but maybe he will make to spec:
http://www.ebay.co.uk/sch/gaviscool/..._sop=12&_rdc=1
Old 10-19-2016, 06:38 AM
  #615
Aresti-RCU
I need to change the bearings of my OS 120 Surpass III. Can somebody guide me in the process? I am concerned mostly on how to remove the piston pin and the camshaft and how to put it back together with the right timing. Putting the piston back in the sleeve is also another concern (not breaking the piston ring!)
Old 10-20-2016, 04:02 AM
  #616
SuperNash
This...
https://www.youtube.com/watch?v=S_HrTCCO-GY
...is for the FS 52, but all the Surpass series are constructed the same way, and the timing is set just the same.
Once you have the head off, the pushrods can be removed. Then the cam cover comes off, and the cam will just fall out.
Piston pin comes out the back of the engine. If you pull the liner, it will exposes a hole, through which the pin can be removed.
It seems from many peoples experience that the pin may be gunked up, and it may need some cycles of soaking in methanol / heating, especially if the engine has been run on a castor mix.
Old 10-31-2016, 04:20 AM
  #617
Aresti-RCU
Started with a 56 alpha, got the engine disassembled but the bearings are stuck in the crankcase...more heat?
Old 10-31-2016, 02:03 PM
  #618
knuckleball
knuckleball's Avatar
Reference:
OS FS-52 Four Stroke RC Glow Engine Disassembly
Heat gun or hair dryer works very well on the case to get it hot. As shown in the video a surface like wood is needed. If more than the crankshaft is needed for removal use a brass or similar or steel punch and a small hammer to tap around the bearing(s) to push out. ONLY tap on bearing NOT case..
Old 11-03-2016, 09:30 PM
  #619
the Wasp
oops,,
can any one here help me in this post here>
http://www.rcuniverse.com/forum/glow...-question.html
thanks, big time !
Jim
Old 12-03-2016, 11:05 PM
  #620
Dealspeed
My Feedback: (17)
Dealspeed's Avatar
Count me in for the OS club, by far my most favorite engine maker.
here is my list of OS engines
OS 46ax x2
OS 55ax
OS 50sx
OS 91fx x2
OS 25fx x2
OS 46la x2
OS 25la
OS 120ax
Old 12-05-2016, 06:19 AM
  #621
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
My OS Alpha .56 is almost installed in a GP Cherokee 40, gotta lot left to do in making the cowl opening neater, connecting the throttle. The RotoFlow 10 oz tank is roughed in. I discarded the stock 11 oz tank. A .56 four stroke will run a long time on 10 oz of fuel. The TurboHeader fits right in the rear corner of the cowl.. I will cut the Dubro extension off to make it look better. The prop is a Xoar 12x6 the spinner is a Kavan backplateless spinner from Hobby-Lobby, can't get em anymore.
The instructions call for 4 and 15/16" from the firewall to the face of the prop driver, that is wrong. 4 and 3/4" is more like it. I was fortunate to have an extra 40-70 mount as the first was not usable with the holes so far out.
ID:	2192305   Click image for larger version
Old 03-11-2017, 04:56 AM
  #622
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
What was the OS engine designation for the bushed fourstroke 70, Thanks, Dave
Old 03-13-2017, 07:16 AM
  #623
Bax
The O.S. FL-70 was a non-ringed four-stroke engine, but did have a ball-bearing-supported crankshaft. O.S. did not make a bushing four-stroke engine. Even the old FS-75 used ball bearings.
Old 03-13-2017, 08:36 AM
  #624
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Thanks Bill, I lost it to another buyer anyway, I'll get another chance one day. I definitely misunderstood about bearings.
Old 03-15-2017, 04:39 AM
  #625
controlliner
controlliner's Avatar
What is the most running time you have logged in on your OS Alpha four stroke engine? I'm concerned about the valve seats on these engines being plated instead of having bronze inserts. I notice the valves reciprocate directly in the bare aluminum of the head as well...sigh... cost cutting?
