OS engines users Club
Old 09-06-2017, 08:20 AM
  #701
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
The aforementioned OS LA 25 on the LT 25, it's angled to the right because I originally flew it with an Enya .25 Diesel and the muffler wouldn't clear the fuse side with the engine straight up. LT 25's build fast and accurate and I use only Super Phatic glue, no epoxy or CA.
Old 09-06-2017, 03:56 PM
  #702
N1EDM
Hi guys,
I need help with another engine question. I purchased a OS FS-91 Surpass (not Surpass II, etc., it's an early one). It needed bearings but that seemed about all. I fired the engine up on 10% fuel (just cracked the jug last week) and it smoked like a banshee. She got 9400 RPM with a 14x6 prop (pretty respectable for a vintage 4-stroke, eh wot??) but still smoked badly. I was able to get a nice idle out of it, too. Plug is an OS Type F.
I realize that the LSN also tunes the midrange but this seemed to have little to no effect. The HSN is on the verge of being lean. The carb is clean, the valves are set to about 0.4mm, and the piston is clean, as are the valves.
I had originally suspected a stuck ring but the ring is clean, unstuck, and has plenty of expansion left in it.
Any thought? The engine seems almost perfect except for the great gobs of smoke (no exaggeration) coming from it. I haven't checked the timing, but would I get those good an RPM number if the engine was mis-timed?
Bob
Old 09-06-2017, 09:38 PM
  #703
Broken Wings
My Feedback: (20)
Broken Wings's Avatar
Talking
Originally Posted by 1QwkSport2.5r View Post
Yes, I'll cut a Boost channel into the crankcase. The crankcase is cast as if they intended to have a boost port, but never machined it in.
Sure, why wouldn't you want to modify an OS Engine.......the Fox stuff worked out so well......(Smiles) If only (you know who) was here to show you the way.......
Old 09-06-2017, 10:14 PM
  #704
Broken Wings
My Feedback: (20)
Have you found any advantage in running an engine on diesel prior to using it with glow fuel?
Old 09-07-2017, 02:42 AM
  #705
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
John, not many engines will run on Diesel fuel without changing the head, a few will though. I have an OS LA .46 that I bolted a Davis Diesel head on to without breaking it in first on glow. Mr. Davis recommended breaking converted engines in on glow first. My Saito .80, (15.5 to 1 compression ratio) will fire up and run on Davis fuel with the coil removed from the plug. It will turn a Bolly 13.5x8 at 8,760 rpm and idle below 1.400 rpm.
Bob, it sounds like the .91 is in good shape and timed correctly. My guess is that the LS needle is too rich. I'd personally would screw it in until the engine hesitates when opening the throttle then back it out 1/8th to 1/4 turn, you should find the sweet spot close to that setting. Let us know how it goes, Thanks, Dave
Old 09-07-2017, 08:03 AM
  #706
1QwkSport2.5r
1QwkSport2.5r's Avatar
I've done a Picco and Novarossi engine too. They run damn hard compared to stock. Buggy/truck engines often gain double their horsepower output and 30-60% more torque by making modifications to the internals. Boring the crank and changing the inlet timing alone can have a dramatic effect on power - often increasing fuel efficiency enough to gain 20-30% more runtime per tank of fuel as well.
I don't care what brand of engine it is - if there is a purpose to change the powerband or change the overall behavior of the engine, then I will make changes to get the result I want. So far I haven't had an engine fail except one and that was due in large part to a defective engine from the get-go.
Old 09-07-2017, 11:27 AM
  #707
sarpet
Imade boost port cva engine and it rews 1000rpm more with apc 8x4 prop.
icopy it from cvr engine.
Old 09-07-2017, 11:44 AM
  #708
1QwkSport2.5r
The CVA didn't have a Boost port either? I thought the LA was the only series like that.
Old 09-10-2017, 10:02 AM
  #709
Broken Wings
My Feedback: (20)
I understand that, I was just wondering about a relatively cold break in. What is the reasoning for breaking in the engine on glow fuel first? Because it's a conversion?
Old 09-10-2017, 11:22 AM
  #710
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Mr. Davis says that the reason is to get the carb settings right and of course to limber up the moving parts although the Davis Diesel fuel being more "luby" I don't see how a break in on the Diesel fuel would hurt. I didn't break in my SuperTigrre .51 or my LA .46, they ran fine.
Old 09-10-2017, 05:57 PM
  #711
1QwkSport2.5r
Generally, diesels run cooler than glow engines do, so for the engines that take a long time to break in, it takes a lot longer to break the in as a diesel. In general, diesel fuel is about twice the cost of glow fuel, so I can see why Bob Davis recommends breaking in conversion engines on glow fuel first. I would surmise that ringless tapered bore engines wouldn't be a big deal to break in as a diesel conversion, but a ferrous engine would undoubtedly benefit from a glow fuel break-in due to the need for heat cycling the ferrous parts for the right fit.
When I broke in my .25FSR with a new piston and liner, I followed the process outlined by Adriansmodelengines.com to heat cycle over 8-10 runs. The engine ran beautifully as I'd expect it to (remember that gold standard? ), but even after an hour of heat cycling, it still wouldn't hold a needle setting without sagging. A few more runs should have it ready for diesel duty. I got a NIP Davis head for the .25 for $5 from my LHS. Quite the bargain considering the engine was a freebie and the piston/liner was "only" $40.
Old 11-14-2017, 05:38 AM
  #712
Linkan2
Hello
I have bought an OS 200fs.
There is much written about this engine here in Sweden.
About how to get the engine going a lot better.
It is so that the valve springs have different hardness.
Then replace the soft valve spring with exhaust gas.
For harder harder valve spring number 45560210
so now I'm waiting for my valve spring
Lars
Old 11-14-2017, 06:13 AM
  #713
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
OSMG924745560220 Exhaust 18mm length
OSMG924645560210 Intake 20 mm length
Old 11-14-2017, 02:54 PM
  #714
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Two years or so ago I bought a new OS 56 Alpha, moved the vent to the back plate because it would nearly stall every couple of minutes during a flight. Now looky here.
**Additional Technical Info Will Be Added When It Becomes Available.**
This is the O.S. Engines FSA-56II Four Stroke Engine with the F-4040 Silencer.
FEATURES
Blow-by oil exits through the breather nipple on back plate for more
stable operation
Black rocker covers
40NA carburetor
Power Box designed muffler for quiet operation is fully positionable
for tight fitting applications
Two-year limited warranty through Hobby Services beginning at date of
purchase
It wasn't my imagination.
Old 11-14-2017, 05:55 PM
  #715
extra300crazy
extra300crazy's Avatar
Hobbsy,
Perhaps so, but i've been running the 72a, 81a, and the 110a for several years without such a problem. I can't believe it was just my luck. I believe that O.S. simply wanted to skip the machining process involved with the rebreathing design to save money and keep their price point and profit. They raised the price as well. I have 9 of the Alphas that have been trouble free.
Karl
Old 11-14-2017, 06:04 PM
  #716
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
I'm genuinely glad your's work well, mine didn't, I'm thankful that the .95v and the .62v I just bought have front vents. But our "speriences" are different for most of us. Variety is good. Thanks
Old 11-14-2017, 06:19 PM
  #717
extra300crazy
Hobbsy,
My club has a few of the 95v's running and they seem like fantastic engines. I have to wonder why O.S. didn't see fit to incorporate that design in the rest of their 4 strokes, because their cost is more in line to normal pricing that people would be willing to pay. I just can't see the cost justification in their new line of series ll alphas.
Karl
Old 11-15-2017, 03:50 AM
  #718
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
The V series are mfd. in China, that might explain the better price. Here's a shot of the .95v interior I took when it arrived. It is a smoothy. This was taken after a 50 minute run on Wildcat 10% full synthetic. The only fuel I use now.
Name:	OS 95v 1.JPG
Old 12-03-2017, 04:59 AM
  #719
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
I Have been ciphering on and examining this OS 1.20 Surpass for a couple of months. I have effectively disabled the stock regulator by removing it's spring, so I haven't ruined it. By choking it I got fuel to carb easily through the IronBay regulator. I'll run it tomorrow, the prop is a Graupner SuperNylon 15x8. When the prop is moved either direction the fuel moves back and forth in the return line indicating that the gear pumps works well.. The recirc line is disconnected because it breathes so freely it negates the intake stroke, no kiddin, it needs to be restricted some way.
Name:	OS 1.20 with IronBay regulator..JPG
ID:	2246735   Click image for larger version
ID:	2246750   Click image for larger version
Old 12-03-2017, 06:54 AM
  #720
extra300crazy
Let us know how it runs. Did you attach the header to the exhaust port with teflon tape?
Karl
Old 12-03-2017, 08:16 AM
  #721
RACE 66
Thumbs up Enlighten on Boost Port Addition
sarpet: Enlighten me about the boost port on the cvr with the transition to the cva. I have a couple of articles on modifying liners/cases for boost port additions. I to have a cva I would like to 'rev up' the little cva up some. Thanks
RACE66
Old 12-03-2017, 10:54 AM
  #722
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Karl
Yes sir, that is standard practice for me on four strokes, I've never had one come loose since doing that, no matter the brand. I pulled the head and the engine appears to never have been run. I'll go easy on it because of that and the fact that I am not sure how well the fuel system will pass fuel in it's new configuration.
Old 12-03-2017, 03:24 PM
  #723
extra300crazy
Hobbsy,
I'll give the teflon tip a try, thanks.
Karl
Old 12-03-2017, 05:41 PM
  #724
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
I don't have any Teflon tape on the adapter because I never removed it.
Old 12-11-2017, 10:00 AM
  #725
blw
blw's Avatar
I've never had to use Teflon tape, but I know it works well. I always have a roll in my tool box when I fly.
