Webra Speed 20 Marine
Old 01-24-2006, 01:41 PM
jetpack
jetpack's Avatar
Default Webra Speed 20 Marine
Does anyone else have this motor?
It is discontinued and was wondering who might have a parts list, parts diagram, suppliers, or what could be swapped with current versions.
The one pictured is what I picked up, dis-assembled and cleaned. It needs a head shim, possibly bearings, a pipe header, and a return spring. I suspect the case being the aero version. The last pic is showing the difference in the case, note the size of the manifold ears. Which case is correct?
The Webra website was of some help for carb parts, but the internals I'm going to need help.
ANY help or suggestions will be appreciated, thanks.
Art. Nr. 1018RCW ABC
Artikel WEBRA SPEED 20 RC ABC
wassergekuhlt mDyn.Verg
ID:	394495   Click image for larger version
ID:	394496   Click image for larger version
ID:	394497   Click image for larger version
ID:	394498   Click image for larger version
ID:	394499   Click image for larger version
ID:	394500   Click image for larger version
ID:	394501   Click image for larger version
Old 01-24-2006, 07:30 PM
RaceCity
RaceCity's Avatar
Default RE: Webra Speed 20 Marine
Try this:
http://www.webra-austria.at/
Old 01-26-2006, 08:07 PM
jetpack
jetpack's Avatar
Not sure if they translate english emails but i'll give it a shot anyways.
Old 01-29-2006, 07:39 PM
jetpack
jetpack's Avatar
Webra replied with a parts diagram that included a parts list.
They stated this motor was stopped in the mid '80's and do not carry the head assembly or the flywheel anymore. Most parts are still available.
The correct parts listing is carried on the right side of the table.
The diagram I do not agree with as the head assembly shows an eight hole bolt pattern, the actual is only four. It also only depicts the heli version. The marine version diagram was not supplied. I also added the proper Dynamix parts diagram.
ID:	398003   Click image for larger version
ID:	398004   Click image for larger version
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
