What should the cylinder sleeve look like?
As I try to resurrect an engine from the dead, I'm wondering if I need to somehow hone the cylinder. The inside is baby bottom smooth-almost glass smooth with no apparent scores. Maybe this would be called glazed? It had thrown the retainers, and had a busted ring. There are dark 'streaks' running up and down in places. I've ordered new piston and ring (ST G4500). Ya, I bought it used and trying not to spend a fortune on parts. Bill
RE: What should the cylinder sleeve look like?
You re right, you have to break the glaze - or the new ring will never seat. I use a brake cylinder hone picked up at the local AutoZone for (I think) around $20. I have picked up old engine restoration as a tangent hobby and so it was an easily justified purchase. Anyhow about 15 minutes with the hone shuld genrate a nice fine cross-hatch pattern on the cylinder and the engine will break in like it was brand new...
My Feedback: (24)
Jim is right.
One thing you can do to make it really easy is go to an auto parts store and ask for a "brake cylinder hone". These are for honing the little cylinders in hydraulic drum brakes and will be small enough to fit inside your model engine cylinder.
Put the hone in a cordless or corded electric drill motor. Now use plenty of oil, and while spinng at a slow speed, move the hone in the cylinder up and down at a steady but medium speed. Remove frequently and check for "cross=hatch" the little pattern of a properly honed cylinder. When you see it, flush the cylinder out and remove all traces of grit and then coat it with oil and assemble your engine.
