Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Glow Engines
 webra, back of engine tapped for pressure? >
Old 03-01-2006 | 11:40 PM
My Feedback: (97)
Default webra, back of engine tapped for pressure?
I recently purchased a Webra 91 and in the back of the crankcase is a fitting like on a muffler for pressure. I had to block it off for the engine to not spit fuel out. Any ideas why someone might tap into the crankcase?
Thanks, Denny
Old 03-02-2006 | 03:14 AM
Default RE: webra, back of engine tapped for pressure?
The tapped hole is there so you can use a pump like the Perry regulator VP30. But I think some people run them without the pump with good results.
Old 03-07-2006 | 12:23 PM
My Feedback: (97)
Thanks for the heads up, makes sense to me.
Denny
