Which tachometer?
Old 03-28-2006 | 11:10 PM
RVM
Default Which tachometer?
I've never owned a tach before. However, since I'm getting into 4c engines now, I think I'll need one. [8D] Can you folks recommend a reliable and accurate tachometer? I've seen tons out there, most of which seem cheaply made.
Thanks!
Old 03-28-2006 | 11:13 PM
w8ye's Avatar
My Feedback: (16)
Default RE: Which tachometer?
Most of them work, it depends on how much you want to spend.
The $20 one needs a good bit of light and you need to be close to the prop.
The $100 are a lot better
Old 03-28-2006 | 11:14 PM
RVM
Any specifics? Anything I should look for? Are lighting and distance to prop the only distinguishing characteristics between spending $20 on a tach and $100+?
Thanks!
ORIGINAL: w8ye
Old 03-28-2006 | 11:22 PM
w8ye's Avatar
My Feedback: (16)
Lighting and distance are the main factors.
Many people get along fine with the Glow Bee type
Others feel they need a TNC type tach.
http://www.rcuniverse.com/forum/m_36...tm.htm#3669439
Old 03-29-2006 | 12:08 AM
tuwood's Avatar
I bought the hobbico one for $25 & it seems to work ok. I pretty much have to hold it in the shadow of the prop for it to work. In general as long as the prop is casting a shadow I lay it on the ground & watch it from a safe distance.
http://www2.towerhobbies.com/cgi-bin...&I=LXPT32&P=ML
Old 03-29-2006 | 05:16 AM
DarZeelon's Avatar
Robert,
I would second Tony's recommendation.
I have the Hobbico tachometer and it works pretty well even on cloudy days.
You sometimes have to change viewing angles to get a consistent reading, but experience will easily teach you when it is not showing what it should.
The only thing that really affects it... don't take readings in close vicinity to extreme voltages (high tension wires, F.E.), or your 10,000 RPM would appear to be 31,000...
For $20 you can't go wrong.
Old 03-29-2006 | 11:23 AM
in lowlight conditions I ziptie my cheap tachometer to a small maglite, works great.
