Need Instructions for old OS 7M carb.
NH
I picked up a clean OS 61 FSR ringed engine last year. I put in on the test stand and it ran very well. It has a 7M carb on it, however, and I have no clue as to how to set the low end on this type carb. It has two adjusting screws on the same side of the carb as the needle valve. No one at the local Hobby Shops or in my Clubs can remember what the two adjusting screws do. This carb was on some OS engines in the mid 80's. So if anyone has some info on this type carb, I would appreciate the help. Thanks in advance.
MB, CANADA
RE: Need Instructions for old OS 7M carb.
I have an 1986 OS .61 SF. MAX W/pump. I don't know what carb it has, bought it with a bi plane, there is lots of screws. for adjustments, I got a manual from OS Mfg. or rep. in pdf formate I'm not sure if I can upload it to you, I will try. let me know if you get it , if not I'll try to find the thread where you can as for the manual.
roltech
roltech
MB, CANADA
ORIGINAL: Cutlass 60
roltech
NH
My thanks to Roltec, Loughbd, and LTE3 for your kind assistance in getting me some info on the 7M carb. Very much appreciated.
Hello to all !!!!
I have this engine that was giving to me with the 7M Carburetor.I would like to remove the brass ring in the carburetor intake.Can you e-mail me the instructions for this carburetor. I will appreciate very much for your favor.
Thank you.
Gus Agner
My e-mail is: [email protected]
Thank you.
Gus Agner
