How Do You Secure the Exhaust Pipe/Muffler?
My Feedback: (9)
I have several four-strokes...nice engines but they all have a common problem. The exhaust pipe/muffler won't stay secured. Every flying session I have to stop or land early and tighten up the exhaust system. I have tightened most of them up as much as I dare - in fact I broke the head exhaust flange on one engine - but to no avail. Any tricks out there about this that can solve the problem for me?[]
Thanks.
Thanks.
MO
RE: How Do You Secure the Exhaust Pipe/Muffler?
I have cured this in two different ways.
Teflon Tape on the threads, even under the jam nuts, and blue locktite. If they are really stubborn. meaning that the blue locktite doesnt work, you can use red (High Temp, High Strength) Locktite, but you may never get them apart again. Red locktite requires 1300 degrees or more to brake down and loosen is I am correct with the numbers. I'm sure someone will correct me.
My Feedback: (24)
There is another method, albeit rather complex and requires some mechanical skills and extra tools.
You can drill a hole in the exhaust nut, and then safety wire the nut to the head.
You need to buy a nut drilling jig:
With this tool, you drill the corner of the nut. Then you use stainless steel aircraft safety wire:
After you mount the exhaust pipe and tighten the nut, you run a piece of wire through the drilled nut and then around the cylinder head, tightening and twisting the wire ends together. The nut will not loosen again until you cut the wire yourself.
http://www.whizwheels.com/Tips/safetywiring.html
My Feedback: (9)
Kmot, this is the professional way to do it without doubt. Being a ham-fisted, impatient modeler, I'm going to try the teflon tape method first. Thanks all for the tips. BTW, my first car was a '65 chevy SS convertible. Landed my first wife with it.
MO
Great to hear about the 65 SS Convert. My Baby is a 65 BelAir Wagon. I use it as a business car and a tow car for our gear when we attend several Midwestern Car Shows. It is a Wagon, but in process of making it an SS Clone
The trick seems to be tightening things after the engine is hot along with the teflon tape. Maybe I've been lucky so far, but after checking the tightness after a couple of hot runs, then it's staying nicely in place.
What I really like about using the tape and getting things snug is that the leaks and castor mess on the pipe and muffler are non existant. The mufflers that become all castor stained is from slight leaks that build up.
Ernie
Ernie
I used teflon tape on my Keleo twin exhaust header (OS-160FT) and it stopped the nuts from backing out as they tended to do after a few flights. However today the right jug side exhaust header flange busted clean off![:@]
Guess I'll send her back to old Kelvin and see if he can fix it for me. I must have excessive vibration somewhere, but the prop is balanced perfectly, so that ain't it.
Putting red RTV silicone works great for locking threads, it adheares to various materials, yet isn't too strong so you can take things apart when you need to. I put it on everything.
My Feedback: (9)
Here's one exactly like my original beauty. It wasn't fast (283/2-speed powerglide), but the girls loved it.
ORIGINAL: 65 Chevy
OH
In my experience, the (high temp) RTV, or teflon tape, is the way to go.
Red Loctite begins to degrade at around 600 degrees F, which is still warmer than I would want to heat an engine to remove a broken header pipe. If you want to use a Loctite product for this application, try Loctite RC/680. It's green in color, doesn't require the components to be squeaky clean, will cure without a supertight fit between the components, and you won't need a pipe wrench to remove it.
Another vote for red RTV silicone. It has held exhausts fast on my YS, Saito and OS four-strokes and does not present a problem breaking free when it comes time to remove the parts.
The leak sealing is a very welcome bonus too.
