exhaust extensions
exhaust extensions
Does adding exhaust extension to your 2 stroke engines cause problems? I am running twin os46fx's in a mossi and I need to divert the exhuast a bit more than the mufflers do. I have used the dubro (gray) exhaust extensions in the past but was once told that they can cause problems and cause your engine to run much hotter.
any thoughts and/or advise is appreciated.
Happy flying,
Mike,
Happy flying,
Mike,
TX
RE: exhaust extensions
What is more important, diversion of exhaust gases or 100 more RPM? You have to make the decision. I would suppose there is some loss of RPM but not noticeable, and perhaps some increase in back pressure. But I use them with no apparent problems, usually to do what you want to do, divert exhaust gases.
Good luck,
Cheers,
Chip
Good luck,
Cheers,
Chip
