Safety wire?
Safety wire?
I'm new to using YS engines. Do I need to safety-wire all the fuel line connections at the check-valve, filters, etc, to keep the pressure from separating a fuel line somewhere? I'm using medium fuel tubing.....
My Feedback: (102)
Clips
Hr, there are clips available for that from several sources, I have two YSs but I only put clips on the fuel filter because where the fuel line attaches is kinda short. Also there are barbs available to solder on the brass pipes into the tank.
Safety wire?
I'm gonna piggy-back a question here...I have two strokes and use a 1/4" piece of tubing slipped over the fuel tubing to secure the line to nipples. Is this adequate, or am I creating a problem waiting to happen? Thanks.
