Cline check valve install
1 Post
RE: Cline check valve install
It does pass air in the one direction - blowing from the brass ferule side, it does seem quite hard to blow through, the other direction does not allow any air to pass through.
My Feedback: (14)
ORIGINAL: scratchonly
I'm curious; what does the check valve acheive? Does it help a poorly placed tank?
It allows pressure over atmospheric (pressure pulses from the engine's exhaust or crankcase) to build up in the fuel tank, which the Cline Regulator then "regulates" back to the carburetor. Without some pressure differential between the fuel tank and the carb, the regulator has nothing to regulate. <G>
NY
I just purchased a FORMOST check valve and plan on installing on the pressure line from the exhaust to the fuel tank. My attempt is to correct a problem losing back pressure on the low end. The fuel tank is not cracked and the cap is on securely. will this attempt help my problem by using a check valve?
My Feedback: (102)
It will cause you a big headache, the pressure will build up in the tank at full throttle and then when you go tp part throttle the pressure will be trapped by the check valve and cause you a very rich midrange. A check valve captures the peaks of the pressure pulses, so the tank pressure is very high, in the order of 6 to 9 psi.
Well I suppose that one doesn't have to use the regulator if they are racing. Then it is full throttle, go fast and turn left, after the race, cut the throttle to promptly kill the engine and dead stick on in. Using a pressurized fuel tank lets you run at peak RPMs and you can bore out the venturi more too.
NY
If I used this check valve, i plan on relieving the pressure by pulling the exhaust hose off the check valve after each flight. When the weather breaks i plan on trying this new set-up. But first, I wll try and adjust the LSN first to see if that solves my problem.
