What about the ROBART fuel pump?
Old 02-22-2003, 05:33 AM
FW190D
Default What about the ROBART fuel pump?
With all the discussion contained in this thread regarding the Perry pumps, as well as the Cline regulator, I was surprised to hear no mention of the ROBART fuel pump. I purchased a ROBART No. 209 Super Pumper Mk IV at a sale for about $5.00. It is still in its original box, new and unused and I thought I would "someday" find a use for it. The instructions say it is recommended for a 60-size gasoline engine. I was wondering whether this pump could be used on my Saito 91 4-stroke. Has anyone out there used one of these pumps before? Are they similar to the Perry in operation and reliability? Should I be able to run this pump equally well on glow fuel?
Thx,
Ken
Old 01-30-2006, 02:55 AM
Philip Taft
Default RE: What about the ROBART fuel pump?
I think that type of pump was not intended for gasoline operation. I may be wrong but I'd hate to see you destroy it.. I've used them on a couple of aircraft before but it requires a bypass line at the venturi to re-direct excess back to the tank....
I'd like to get my hands on a Robart Super Pumper if you know anyone who has a spare they would like to sell..
Cheers Phil
Old 01-30-2006, 03:08 AM
William Robison
See it here:
http://www.rcuniverse.com/forum/m_38...tm.htm#3823160
Bill.
Old 01-30-2006, 03:26 AM
Philip Taft
Hi again, Excerpt from a Peter Chinn assesmant on various pumps follows:- The Robart pump is assembled as a sealed unit and should not be dismantled. Provided that a fuel filter is installed between the tank and pump, cleaning should not be necessary. As with an engine, however, fuel left in the pump after use will , in time, evaporate, leaving the oil content to coagulate and, possibly, gum the valves. This can be prevented by removing the pump (if one is not intending to use it for a
few weeks) and blowing out the fuel remaining in it. Don't use a petroleum solvent and don't poke anything through any of the three openings in the unit: damage to the valve or diaphragm will result. One other thing to watch is fuel composition: home-brewers who persist in adding petrol to their fuel will find that this (and
certain other additives) will ruin the pump diaphragm.
Hope it helps any would be's
Phil
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
