ASP/MAGNUM FS400AR Rebuild/Overhaul
Old 08-16-2013, 02:55 PM
  #2526
retransit
My Feedback: (18)
retransit's Avatar
Carosel43,
I hate extra parts!
I may be wrong, but I'm assuming you used an aftermarket master rod bearing in the previous fixes. If that is correct, than something is not right within the engine separate from defective bearings. Do you agree?
Old 08-16-2013, 03:16 PM
  #2527
BJ64
BJ64's Avatar
Nice little project for you, Caro
Should keep your mind off beating us at cricket
BJ
Old 08-17-2013, 12:04 AM
  #2528
Carosel43
We were playing cricket? I care so little about it I didn't really know! lol
As for the bearing it was a new one and sadly I threw out the old one, I knew I should have kept it! anyway I think the problem is that the crank pin is undersize and so there is a small amount of movement. This turns into an audible rattle when the engine is running and I think this is what did the bearing in. Sadly there is no fix for this problem short of a new crank and to be honest I am tired of throwing money at this engine. I will get another bearing and put it back together but honestly its days are seriously numbered now.
Old 08-17-2013, 12:47 AM
  #2529
BJ64
BJ64's Avatar
Can't you get some sort of sleeve the correct o/d, then maybe machine the crank pin undersize until the sleeve fits over?
Oh... hang a minute - the crank pin would need one of those weird-arsed offset lathe thingies to machine a perfect diameter, right?
BJ
Old 08-17-2013, 12:50 AM
  #2530
Reverend
Reverend's Avatar
Jon,
german INA Bearing on its way to you with the monday mail.
Rev
Old 08-17-2013, 03:09 AM
  #2531
Carosel43
:O thanks Rev, do you just so happen to have a supply of radial parts floating about??
And BJ I did think about fixing the pin but its probably undersize by less than a thou (in truth its probably a few tenths) so a sleeve is no good. Also as the pin is hardened, or at least as close as anything Chinese gets to hardened, it will likely be a pain to machine it, not to mention the fact that it would weaken the pin. add to that the pain in the butt that setting up the 4 jaw chuck would be.....yea I don't fancy that plan, new bearing, put it together and run it until it explodes again!
Old 08-17-2013, 04:00 AM
  #2532
Reverend
Reverend's Avatar
Yep, I do have the one or other odd part in a box called "FS400 Spares".
I bought a new one for mine and got the second one at half price so no worries. Just returning a favour (Sleevenut)
Rev
Old 08-17-2013, 05:15 AM
  #2533
BJ64
BJ64's Avatar
... put it together and run it until it explodes again!
I like your style
BJ
Old 08-17-2013, 08:47 AM
  #2534
retransit
My Feedback: (18)
retransit's Avatar
"This turns into an audible rattle when the engine is running...."
Probably what my Saito 1.80 sounded like this morning. New bearings are in order for the 1.80.
Old 08-17-2013, 09:07 AM
  #2535
BJ64
BJ64's Avatar
Bugger it - I'm off Slope Soaring in the morning.
No pins, no bearings, no motor-shtitting-itself noises.
No fuels to mix. No oil daggies all over my fewz.
No glow-drivers... 32 servos... dual-double qaudruple anything to worry about.
Just the roar of the Ocean in a 30knt+ wind, and the sound of a sreaming wing to contend with.
Brilliant...
What can possibly go wrong ???
BJ
Old 08-17-2013, 10:44 AM
  #2536
Carosel43
retransit - the rattle is like a clattering sound that's very obvious when the engine is warm. It sounds like the engine is knocking but its not.
And Rev you don't owe me for the sleeve nut so don't worry about that.
BJ...You could fall off the cliff...that would be bad
Old 08-17-2013, 12:42 PM
  #2537
blw
blw's Avatar
Carosel43- I've followed your progress and was sorry to hear of yet another problem. Good luck.
Old 08-17-2013, 02:02 PM
  #2538
BJ64
BJ64's Avatar
.. the rattle is like a clattering sound that's very obvious ...
You sure you haven't got a Misubishi diesel ?? ~S~
Re falling off a cliff: some would say that that's not such a bad thing.... LoL
BJ
Old 08-18-2013, 07:56 AM
  #2539
Carosel43
I am very sure its not anything close to the diesel. if it were then it might be more reliable!
Old 08-19-2013, 10:12 PM
  #2540
Kmot
My Feedback: (24)
Kmot's Avatar
I think it's because the throttle jockey has a lead shoe (thumb?) and can't keep the rev's down!
Old 08-19-2013, 11:27 PM
  #2541
Reverend
Reverend's Avatar
Don't you try keeping the REV down :P
@Caro: Spent 15 Minutes in the line in front of the post office teller last night thinking about the laser 360 that doesn't fit in the ESM Zero
Have to go with the DLA56 there... Anyways, bearing is on its way.
Putting the Laser in the Wedell Williams now and the FS400 is going back into the Stearman when it finishes. Spent some time painting it
Currently working on the firewall and a small clamshell.
Rev
Old 08-19-2013, 11:31 PM
  #2542
Reverend
Reverend's Avatar
I can actually relate to that... although its not the sea breeze I am looking for but the mountain "foehn" winds...
Rev
Old 08-19-2013, 11:49 PM
  #2543
BJ64
BJ64's Avatar
Ahhh....
Ze mountains of Österreich.
Man, would I ever love to do some serious Slope work over there....
BJ
Old 08-20-2013, 12:27 PM
  #2544
Carosel43
Cant keep the revs down? pff. More revs engine room!!!
Anyway, Rev, I am surprised to hear the laser wont fit the zero, its a shame you do not still have the 300v as the petrol will make a nasty noise
And while your flying site looks super tasty to me, ours is not half bad. The pic below was taken this evening and shows my newest creation. a little baby Nieuport 17 with a very old saito 45 in the nose.
Name:	P1110053 - Copy.JPG
Old 08-20-2013, 03:42 PM
  #2545
BJ64
BJ64's Avatar
Noice
BJ
Old 08-20-2013, 03:59 PM
  #2546
Kmot
My Feedback: (24)
Kmot's Avatar
Originally Posted by BJ64 View Post
Noice
What he said!
Old 08-21-2013, 03:55 AM
  #2547
Carosel43
cheers guys. I am pretty happy with the model. Its a full kit in the old fashioned sense and I only started it at the beginning of july. With a 52'' span it will fit in the car in one piece which is really handy and its lovely to fly. Its a bit of a nightmare to land as the tail tries to overtake the front end the moment the wheels touch. The same is true on takeoff. But whatever, its a lot of fun and I hope to spend many hours puttering slowly around the sky with my friends Se5a in close company
Old 08-23-2013, 04:49 PM
  #2548
Kmot
My Feedback: (24)
Kmot's Avatar
I can't wait for the Fall. I'm fed up with the heat. Every summer is just misery. I am a prisoner of the heat. I do not feel like working on anything during the long miserable summer we have here in the San Fernando Valley. I won't be doing anything to my engine until October.
Old 08-23-2013, 05:22 PM
  #2549
BJ64
BJ64's Avatar
Swap ya for cold and wet and bloody windy
BJ
Old 08-23-2013, 06:45 PM
  #2550
retransit
My Feedback: (18)
retransit's Avatar
I feel the same here in Florida. Must be our age. I'm contemplating moving.
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
