ASP/MAGNUM FS400AR Rebuild/Overhaul
Old 05-01-2020, 05:08 AM
  #3301
keathebch
Originally Posted by grassie View Post
Thanks for the quick response. Yea, I had it that way. I bought new fuel, maybe that is the problem. I will revert to the Morgans LV and see if the problem persists.
Hello everyone, does anyone have any pushrod covers they can let go of. . I need a least 4
Old 05-01-2020, 05:16 AM
  #3302
keathebch
The bottom cylinders seem to stop running, at idle without the glow driver. attached. and you will probably need to run a built in glow driver, that you can adjust to come on with a low throttle setting
Old 05-03-2020, 06:30 PM
  #3303
Kmot
My Feedback: (24)
Kmot's Avatar
This website, RCU, is merely a shell of it's former self. People are chatting up like always, but in a different location. And then there is Facebook, which has User Groups but they are a PITA because they do not use forums. so a post you make will be buried and impossible to find a few days later. Anyway, I probably cannot mention the link to a competing website. So if you are so inclined, do a search for "model airplane engine forum" and you should be able to find an active one.
Old 05-04-2020, 03:22 AM
  #3304
Carosel43
Hi Guys
I dug out my 'retired' radial a few months ago to run it up and flush out all the castor. I then flew it a few times to just give it some air but it ran like a dog and i could barely keep the cylinders lit at any throttle setting.
Being bored one rainy afternoon i took it apart and found a variety of problems. 2 loose rocker adjustors, one rocker retaining clip missing, dead bearings, leaking valves, and of the 3 screws holding the cam drum together one was broken and two were loose so i had variable valve timing!
As it was ruined and a right mess i decided to do what i always wanted. Strip it right down, clean everything and attack it with the shot blaster here at work to make it all beautiful. The idea was that if it didnt run right i could stuff it and mount it as a display item. I repainted the cylinders with engine enamel, painted the rocker covers and even did the enamel on the name tag. Once suitably beautified it was on to the mechanical side. New twin ring pistons stolen from dead Laser 75's, new bearings, valves polished and seats re ground, cylinders brush honed, all the O rings in the intake replaced.
Once together it looks lovely, and the moment of truth arrived..
Starting the engine for the first time showed immediate improvement. The engine was significantly louder with a real bang from each cylinder instead of a wimpy little phutt. Opening the throttle gave and immediate sense of the improvement as the engine sounded really crisp. Up to full power and heavens above its got some go! Power on all props tested so far is 400rpm higher than ever before and for the first time the engine now runs reliably at idle with no glow support. Throttle response is excellent and its easier to tune with really good compression that i have never had before. In general, its now a complete animal and i was recording 7800rpm on a menz 20x8 (7400 previously) and 6800 on a 21x8 (barely 6300 before). The sound is so different with a real bark to the exhaust note. All of a sudden, the engine runs as it should. All it needed was completely rebuilding and half its innards replacing
I will try and shoot a video sometime soon. In the meanwhile there is a photo at the link below. I do have the 5th rocker cover, it just needed another coat of paint
Old 05-04-2020, 09:25 AM
  #3305
SJN
nice, ill send mine over to you for a rebuild on a rainy day :-)
Old 05-05-2020, 02:38 AM
  #3306
Carosel43
I have rebuilt mine so many times i can almost do it in my sleep!
Old 05-05-2020, 11:02 AM
  #3307
Kmot
My Feedback: (24)
Kmot's Avatar
That is awesome Jon! Well done! Looking forward to the video and listening to the bark!
Old 05-08-2020, 08:15 AM
  #3308
Carosel43
Made some more noise
Edit
Oops, small error on the video....
Edit again
Fixed it https://www.youtube.com/watch?v=ct-Z...ature=youtu.be
Old 05-26-2020, 02:46 PM
  #3309
keathebch
Default Push rod tubes/Parts
Hi everyone, i am trying to locate some pushrod tubes used or new, or a substitute, I have cross referenced OS with no luck there so far. Thanks
Old 05-27-2020, 09:25 PM
  #3310
Kmot
My Feedback: (24)
Kmot's Avatar
One of these might fit:
https://www.ebay.com/i/164209712411?chn=ps
https://www.amainhobbies.com/pushrod...966100/p655034
https://www.ebay.com/p/1201483871?iid=252802884323
https://www.towerhobbies.com/cgi-bin...1p?&I=OSMG7412
Old 06-25-2020, 11:03 PM
  #3311
Benny p
what thread is used on ASP FS400AR propellor shaft?
Old 06-26-2020, 02:52 AM
  #3312
Carosel43
3/8x24 unf i think
Old 08-29-2020, 03:19 AM
  #3313
kgo068
kgo068's Avatar
Well ,hello everbody. Its Kym from Australia here again. I think it was around 2013 !!! since I posted ,but have looked in from time to time.
Believe it or not I got my 400r out off storage to get it going again. If you remember it was mounted on an ESM 85" Corsair, the whole setup flew ok ...but was severely underpowered. It was around 15kg!! So parked it all up .Corsair is still waiting.
So, the 400 sounded clicky when turning over..cam followers I suspected. So pulled it all apart. Yes the dreaded rust ,same as the photos here, I've seen. Cleaned up good ,replaced bearings. All smooth now.
NOW.. the big question. Will this motor run if its timing gear is out by 1 tooth?? When I reassembled and matched the timing dots, to me, 1 of those dots was not quite in the valley on the tooth. I wish I took photos. I took my best educated guess as to which way to go . Even though I have to run again and check it out , I got it to rev out at 4500rpm, at the most ,on a 20x8, and it idled just ok.
Would it still run if out by 1 tooth? Or not at all? Thanks guys ,I will try and get it in a plane and get my camera out!
Old 08-29-2020, 02:16 PM
  #3314
nige69
Hi Kim,
I think you might be tooth the wrong way. t should rev higher than 4500 on that prop. Mine running on petrol with a 21x12 prop will rev to 6000
Old 08-29-2020, 04:07 PM
  #3315
kgo068
kgo068's Avatar
Hi Nige ,Yeah has always revved higher until I started fidling with it .I am going to run it again sometime,then make a decision to strip down again.
Old 09-02-2020, 07:01 PM
  #3316
kgo068
kgo068's Avatar
All good ,mixed a new batch of fuel, Give it a good run on a tank ,slowly tuning it as I went . Got it back to just over 6600 on a 20x8 .Must have got all timing dots aligned up afterall.( thank goodness)
So now just have to wait for Seagull Models to start producing the 103" Morane Saulnier later in the year ,and I'm getting one.
nige69 (09-02-2020)
Old 09-03-2020, 10:22 AM
  #3317
Carosel43
That is still really slow. My engine does 8000 on a 20x8 master airscrew and at least 7500 on a menz 20x8. Sounds like you are down a cylinder at least.
Old 09-03-2020, 05:06 PM
  #3318
kgo068
kgo068's Avatar
Yeah ,I looked at my previous post (88), where I done this test. I can see a few years back ,I was getting 7700rpm,on that very prop.
I still need to see whats going on. Im sure its running all cylinders,But will check this out too. So.. could timing still be out??
10% nitro
Hawk 20x8- 7700- 8.21kg thrust
Hawk 21x8 7140- 9.6 kg
Austars 20x10- 7100- 8.17kg
Austars 22x10 6420- 9.32kg
Xaor 21x8 7200- 9.8kg
Xaor 21x10 6570- 9.71kg
20% nitro
austars 22x10 6750 - 9.75kg
JXF 21x10 6300 - 7.8kg
Turnigy 20x12 7150 - 8.1kg broad blade
Old 09-03-2020, 10:56 PM
  #3319
Grassie1
Grassie1's Avatar
Do you use an exhauts ring and if so do you run a pipe back into the tank for preasure?
Old 09-04-2020, 04:00 AM
  #3320
Hyjinx
10% nitro
20% nitro
He AlL appreciate all the good information on this motor I have a question looks like one of you might know. As these engines are knockoffs of the OS serious engines will parts Fergie ask models fit the Sirius (OS) engines, especially the exhaust ring?
I I just repaired my Sirius fr5 300 and some of the engine parts were obsolete. I was able to get them from Japan from the factory (great folks) but there was limited nos. And they had no exhaust rings. In internal pictures the engines look identical. Thanks fellow radial enthusiasts!
Old 09-06-2020, 11:50 PM
  #3321
kgo068
kgo068's Avatar
Yes ,I run A Keleo ring with pressure nipple. I still have'nt re run it yet ,but I will be for sure- Kym
Old 09-07-2020, 12:29 AM
  #3322
grassie
grassie's Avatar
I made my own ring with nipple but found it almost impossible to tune with tank pressure.
Old 09-07-2020, 01:17 AM
  #3323
kgo068
kgo068's Avatar
When I ran it in a Corsair,I had the ring then,in fact those figures was with ring and tank pressure.I thought someone mentioned this ,I read in these posts somewhere. Is only a tiny carb .
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
