Saito 125 help
GA
RE: Saito 125 help
I think that is the thrust washer.. It goes between the case and the alluminum swirl thing that touches the prop.. I may be wrong..
LATER
LATER
My Feedback: (32)
RE: Saito 125 help
The Aluminum washer goes behind the rubber O ring on the head side of the intake pipe.
The Aluminum washer works like a support, resting against a slight flange on the intake pipe to apply slight pressure on the rubber O ring.
RE: Saito 125 help
Mvallyman is right. The silver gasket goes on the manifold pipe first up against the flange that you should be able to see. Then, the o ring slides on last. Once you *gently* push the manifold into the cylinder head, you will see how it all fits. The o ring will be hidden under the silver gasket once everything is firmly in place. The most common thing that can go wrong is that you slice or nick the o ring if you aren't careful.
The screws that hold the whole carb assembly on to the backplate is what keeps the manifold pushed into the cylinder head.
OH
RE: Saito 125 help
ORIGINAL: okelly
Thanks again guys. Went flying and loved every minute of it . I love this engine.
Three - 82
One - 100
One - 125
One - 150
One - 180
RE: Saito 125 help
ORIGINAL: Ken6PPC
My favorite Saito is the one that I happen to be flying at the time!
Three - 82
One - 100
One - 125
One - 150
One - 180
ORIGINAL: okelly
Three - 82
One - 100
One - 125
One - 150
One - 180
There is one exception to that rule: I love love my 40a more then the rest. It shares the same good qualities as the rest in addition to being so cute!
I have one of each:
40a
82
100
125
180
My Feedback: (102)
RE: Saito 125 help
OK, I have a .40a also that I bought from MOTORMAN37, it's a sweetheart and I have two of the little .30s, also sweethearts. The .30s will turn a Graupner 10x5 at 10,100 easily, Bill Robison loved my .30 so much I almost didn't get it back from him. He borrowed it to help compile his Saito notes. I miss ole Bill, he was good for very interesting conversation.
