Saito 100 No muffler preasure
Old 02-04-2008, 04:39 PM
thunderbolts
Default Saito 100 No muffler preasure
I have a saito FA-100 that I have had to rebuild with new pushrods due to crash damage. I have checked the compression and the timing is spot on. Everything seems fine so try to prime the motor before I start it. For some reason the motor will not prime and I am not getting enough muffler presure to feed the fuel from the tank.
Checked the tank and connections and pipes just cant get the motor to provide the fuel through muffler presure. Primed the motor manually with a little fuel and the motor fires and runs for a second no problem then cuts through no fuel. I cannot see ant air leaks anywhere.
Can anyone help???
Thanks TB
Old 02-04-2008, 04:44 PM
NM2K
My Feedback: (14)
Default RE: Saito 100 No muffler preasure
The engine will run without muffler pressure.
It sounds like you either have a leak in the intake tract or there is a valve timing issue.
Check at the carb base or where the manifold enters the cylinder head for leaks. This assumes that the engine is timed properly and that the valves are operating when they are supposed to operate.
A timing error in reassembly will also cause no suction at the carb to exist. No suction, no fuel. Go over your timing again.
Ed Cregger
Old 02-04-2008, 04:47 PM
w8ye
My Feedback: (16)
w8ye's Avatar
It will not prime if the throttle is closed or the high speed needle is closed
thunderbolts
Thanks Ed.
I'll go over it again to make sure.
Many thanks TB
Old 02-04-2008, 06:20 PM
thunderbolts
Guys,
Timing is smack on. However the clearances on the tappets are not. the inlet side is OK (2 thou) but the exhaust has no clearence at all. None! I guess this means the exhaust side possibly never really closes properly. I have set it to 2 thou and will try again tomorrow.
TB
Old 02-04-2008, 07:20 PM
XJet
Banned
I assume you got the pushrods in the right way up ;-) If you put them in upside down then the valve clearances will disappear and they'll keep popping out of the rockers.
Old 02-05-2008, 03:32 PM
thunderbolts
Success!! Checked the timing again and it was fine. Reset the valve clearances, primed here up and she was away first flip. Set the mixtures up and I now have my swiss watch back!!!
Thanks for the advice guys.
TB
Old 02-05-2008, 04:06 PM
blw
blw's Avatar
Glad you let us know, TB.
Old 02-05-2008, 04:08 PM
thunderbolts
Just one more thing. Is Xjet correct on the pushrods?? Do they have to be a particular way up?? Seems a little strange to me.
TB
Old 02-05-2008, 04:44 PM
blw
blw's Avatar
Xjet is right. The pointed end goes under the rocker arms, inside the cup. Here is a pic of them:
Old 02-05-2008, 04:49 PM
thunderbolts
Great thanks for that.
Looks like I got it right. Just need another plane for the motor now!!!
TB
