Magnum .91 inverted on FLiton extra
I want to mount my magnum inverted.. but I know fuel tank placement is going to be a problem... Should I use a regulator or a pump to solve the siphoning of fuel??? Can somebody link me to one or the other.. whichever is better?
RE: Magnum .91 inverted on FLiton extra
I have had my magnum 91 fs inverted in several different ARF`s with no problems at all. I have never owned a regulator or pump
Ooops, I forgot to ask if there`s anything special about the tank placement in your model?
LA
I would look into getting a cline regulator. I have had great success with them, especially in my fliton model with a CG mounted tank.
CA
If the tank is too high then you will need something as you would with any engine (other than a YS or other pumped engine).
I've used iron bay regulator with success.
