Club Thunder Tiger?????
#102
RE: Club Thunder Tiger?????
ORIGINAL: ttomcat50
Little help. I have a tt pro 46 bb that's about one year old and has had about a galon of fuel through it since break in. I spent plenty of time doing a thorough break in and the engine ran great for the first year. Then, during a flight, I lost power. The engine didn't quit, but would bogg down when applying full throttle. I have it on a bench now and it does the same thing. It starts right up, runs up fine, then after a minute or less, I have to back off the throttle to keep it from dying. I can sort of gun it, intermittently to get it back up to speed but it will still only run wide open for several seconds. I haven't taken anything apart, but the crank shaft turns very smoothly and the glow plug has been replaced. Mixture seems to be right. Any ideas?
Tommy
Tommy
First there was a clear correlation when weather was on the colder side and, in particular, wet with high moisture in the air. No such problems when warm or dry. It seemed that richening the mixture helped. Since the problem showed up at colder temperatures, we started to use a kind of a small light aluminum screen for the head when cold. But then later the problem escalated. Following the advice gotten on this Forum I tried to switch to 10x5 APC (before we flew with 10x6 APC). I liked it more since lower thrust on idle makes it easier to land. Alas, the problem with full throttle aggravated so much that I had to put back 10x6. The engine could half-die, or completely, on takeoff! Now this behavior is observed already at relatively warm temperature... And richening mixture within reasonable limits does not seem to help.
Something to consider as possible hints: originally the engines had a rather pronounced peak over the needle mixture position. This is not so anymore, although I regularly flush the carb assembly with the gas through the fuel line. (Originally clogging of the needle seat apparently caused problems at some regular intervals).
I am flying on the fuel containing 8% Klotz, 10% Castor, 2.5% acetone and 79.5% methanol (the numbers may be more approximate, but I'm pretty confident the components sum up to 100%!) The plug is Tower Hobby one; for unknown reason they have to be replaced from time to time, otherwise the engine refuses to work stable... Otherwise the engine is fine. Very tight when cold (it is difficult to crank cold below freezing), starts well (but does not like priming it is easy to flood it).
#103
Have you tried any different fuels ? I think first thing to suggest would be a 5% nitro popular brand fuel and work from there. My GP 42 likes up to 15% nitro without problem. And it makes some excellent power. Although I may need to increase the timing a little at the crankshaft intake opening.
#104
ORIGINAL: jeffie8696
It would be good to understand the cause of the problem anyway. Otherwise a situation is quite possible that the engines will run with 5% nitro without problems for some time, but then it appears necessary to raise it to 10% etc....
#105
I suggested it so you may be able to eliminate the fuel as the source of the trouble. I have been victim of a bad jug of fuel before to the tune of an engne that wouldn't.
#106
Nick
#107
Do you feel it may be a little too tight and when it heats up good it is siezing? Perhaps too rich and running too cold or too lean and running hot?
#109
Maybe I should try to partially block the muffler back hole (reduce its diameter), to relatively boost up back pressure on high RPMs? I recall once early on we had similar symptoms which turned out to be caused by the loose bolt which tightens the two muffler halves together. We found this out when landed the plane with motor still working, apparently the fit was sufficiently tight with the muffler cold, while the pressure was progressively dropping when aluminum expanded upon heating. But since then we always had this thing under scrutiny, the bolt is really tight now.
What else I can try to do? I have an IR temp meter and can try to watch the cylinder head temperature but, of course, not in flight. What it should be? Also, I can accurately measure the glow plug temperature (more precisely, of the spiral). In this way, actually, two years ago I was able to find out why my Tiger Shark .56 was refusing to run stable on the plain methanol/castor mixture, and made some changes that made it to work flawlessly. But, again, this is all limited to the bench-like tests, even if in the plane.
Nick
#110
I think you are on the right track. Head temps are another diagnostic aid , I can not personally tell you what they should be but perhaps one of the other members will provide that.
If all else fail you can ship it to me and I will do some comparisons to my own and let you know what I find out.
