Saitio 130T vs OS 120 Gemini Twin Mounting Dimensions
My Feedback: (83)
SC
I just received an OS Gemini twin that I was going to put on a plane that belonged to a recently deceased club member. (I bought it from his estate). The plane is BEAUTIFUL, and I dont want to go into the firewall to change the mounting holes. His fabrication skills were much more advanced than my own and I cant bear to cut into the fuse to get to the back of the firewall.
I knew that he had an OS 120 twin on it, but I didnt know that there were mounting dimension differences between the original Gemini 120 twin and the newer Gemini II 120. Just my luck, he had the newer version on the plane and the mounting plate is off by just enough to require that the blind nuts be moved.
My question is this: How do the mounting dimensios of the Saito 130T compare to those of the newer Gemini II (or the OS 160 Gemini twin)? Anyone own both and willing to provide the dimensios for the Saito? I have one of these being repaired by Horizon and I dont honestly remember the measurements between the mounting holes. I dont want to shop for a Gemini II (or a Gemini 160) if the Saito might fit without much modification.
Jim
Jim
