O.S FS120 SURPASS I - Pump
Gents,
Through my own dumbness, i broke the flywheel of the crankcase pump in my old os fs 120 surpass I whilst cleaning it. Does any one have a new backplate with the pump or a used backplate and pump they would be willing to sell?
The pump, which i cannot find the code for[] is the one with a large brass screw in the middle, any othe pupmp will not be compatible with the carb and crankshaft.
Loukis
Loukis
OH
RE: O.S FS120 SURPASS I - Pump
If you can't find the part for your pump, you might try a Perry Pump. The Surpass I is supposedly more compatible with an external pump than the II or the III. Note that I have NOT done this personally. I only took note of an older post that stated that, because I have an OS 120 Surpass I with a pump. When (not IF) my pump goes out, I plan to try this myself.
Good Luck, and let us know what happens if you try this!
Ken
I have a perry pump, dont know how well it will work with the carburetor on the engine. The fuel regulator on this engine was in the pump.
I would like to replace with the original pump. I may have found one...still waiting to see if it will be posted.
