OS48 FS
AZ
OS48 FS
I just acquired a NIB OS 48. It is one of the sweetest running engines I have ever had. Runs and idles like a swiss watch. My question is this: What kind of RPM can I expect running 10% Wildcat fuel with 20% oil and swinging a 11 X 7 or 6 prop. It has only about 2 tanks of fuel run thru it.
Jim Whitney
Jim Whitney
AZ
RE: OS48 FS
Thanks for thr reply but my question is what kind of max RPM should I expect ? 7-8 or 9000 I don't want to change anything out carb or head
Jim Whitney
My Feedback: (264)
MD
RE: OS48 FS
ORIGINAL: w8ye
The only difference in your head and the head of a OS 52 is that the OS 52 head has the glow plug recessed 2 mm farther down in the head and this is worth 300 rpm to you
I don't suppose there is a way of doing this without using a milling machine?
AZ
RE: OS48 FS
W8YE Why would I want an OS 52 carb on the 48? Just curious. The standard carb works very well but does have a small venturi
Jim Whitney
AZ
RE: OS48 FS
The OS48 Four Stroke has an airbleed carb. Mine works like a charm right out of the box. Also It will max out out about 9500 with a 11 X7 MAS prop. So I have answered my original question. Thanks for all the input
Jim
