90TS pipes and plumbing
Hi,
This is my first twin and the manual that comes with it is next to useless as there is little reference to this engine and what there is is not identifiable in the photos as they are washed out.
Sooooooooo.... firstly the included flexible pipes, one has a pressure tube on it. Does this need to go to a particular cylinder or can they go to either cylinder.
Secondly, the line from the tank is pretty obvious that it goes to the carb but there is a second nipple at the intake of the carb? what is this one for?
There is a further nipple on the side of the engine. What do i do with this one.
Sorry if this is straighforward but not for a beginner like me. The manual is a waste of trees Saito!
Regards
Steve
My Feedback: (102)
RE: 90TS pipes and plumbing
The second nipple is for priming, the one on the crankcase is the vent, put a piece of fuel line on it just long enough to get below the fuse. Pressure tap, either cylinder is fine.
My Feedback: (102)
http://www.horizonhobby.com/ProdInfo...oke_Manual.pdf
Steve, here is a much clearer manual, give it afew moments to load.
Thanks Hobbsy
w8ye
I like the idea of the straight pipes.
What do you mean by "Front" and "rear " pipes?
Do these provide a pressure nipple? Could one be fitted?
Steve
w8ye
Steve
My Feedback: (16)
On the 100Ti the front pipe has a pressure nipple and is longer than the rear pipe which has no pressure nipple
http://www.horizonhobby.com/Products...ID=SAI100TI140
http://www.horizonhobby.com/Products...dID=SAI100TI74
http://www.horizonhobby.com/Products...dID=SAI100TI73
