RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Torque Specs (https://www.rcuniverse.com/forum/glow-engines-114/10246741-torque-specs.html)
_Tommy D 01-07-2011 04:19 PM
Torque Specs
Hey Guys
I pretty much make a living over tightening things! Has anyone ever printed a resource for torque specs on small engines like the 2 stroke glows I fly? Or should I most likely refer to a general spec for the size faster I'm tightening.
Tommy D
masama1107 01-07-2011 04:51 PM
RE: Torque Specs
You should apply about 13 lbs/ft of torque on cylinder heads and about 11 lbs/ft of torque on backplates.
Hope this helps.
proptop 01-07-2011 05:09 PM
RE: Torque Specs
You mean INCH / Pounds.....correct!? ;)
Hobbsy 01-07-2011 05:57 PM
RE: Torque Specs
1 Attachment(s)
Here is a chart for the Tork-It, I use 5-7 for most backplates and common sense on head bolts. 4-40 head bolts get about 6, m4 get about 10, m3 about 7, etc.
mike31 01-07-2011 06:24 PM
RE: Torque Specs
I sure hope not. You will be looking for new parts of various metals!
Lnewqban 01-07-2011 07:55 PM
RE: Torque Specs
Tommy,
Consider that the weakest link is the aluminum female thread; so be gentle and only strong enough.
Never tight hot aluminum.
http://www.engineershandbook.com/Tables/torque3.htm
