RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Removing paint from engine (https://www.rcuniverse.com/forum/glow-engines-114/10270646-removing-paint-engine.html)
seagull extra 01-17-2011 05:08 PM
I just purchased a used OS 52 surpass that the PO had given a light coat of spray paint. I would like to remove the paint but I do not want to tarnish the aluminum. Has anybody had any luck removing paint from their engines?
w8ye 01-17-2011 05:46 PM
RE: Removing paint from engine
It will usually wash off with a little glow fuel and a tooth brush?
Regular paint stripper is caustic and will tarnish the aluminum die castings of our model engines.
There are non caustic paint strippers made and they are mainly sold for stripping airplanes but price may not be cost effective.
You could try some acetone
SeamusG 01-17-2011 07:54 PM
Would the "anti-freeze in the crock pot" work as well?
w8ye 01-17-2011 08:35 PM
Yes but it may take a few days
Patxipt 01-18-2011 01:33 AM
Cellulose thinner also works and if you wash it well after application, there won't be any problem.
Cyberwolf 01-18-2011 03:13 AM
Acetone or Laquer Thinner will remove most paints, poly or epoxy paints are very stubborn to remove. But be sure there is not any orings, plastic or such get into contact with it. Another idea is stripper thats used on custom Alum. wheels any auto parts store should carry it in small enough amounts to make it afforable.
Motorboy 01-18-2011 09:05 AM
Use brake fluid to remove the paint without hurt the aluminium parts.
