RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   determining engine size for plane (https://www.rcuniverse.com/forum/glow-engines-114/1039084-determining-engine-size-plane.html)
jlrskymaster 08-09-2003 11:05 AM
Is there a general rule or formula for determining engine size (or power) for a model. Is it determined by weight, wing loading, or some other factor?
Maybe there is a chart or something?
Hobbsy 08-09-2003 11:57 AM
Engine
By what's written on the box or the plans etc.
ilikeplanes 08-09-2003 02:05 PM
I actually made a spreadsheet of the various options for my CG Ultimate. My criteria was overall weight and peak thrust. I wanted the lowest weight and the most thrust. Depending on which is more important to you, you may go toward a bigger or smaller engine. I also considered cost, fuel consumption, propeller size, and four vs. two stoke.
If you're just starting out with a trainer, use the recommended engine size or slightly bigger.
