Overhaul OS 1.20
Who overhauls 4 cycle engines preferably the OS Surpasses?
Overhaul OS 1.20
There are 2 sources that I know of: Hobby Services (probably expensive) and another fellow in Florida that Frank Tiano recommended in RC Report but I can't seem to find the e-mail address.
Overhaul OS 1.20
here ya go: Send to,: John Sepe
301 Sabal Ridge Circle A, Palm Beach Gardens,Fl 33418 email him at [email protected] He does good work , I just got my saito 91 back from him after both bearings went south. Hope this helps and happy flying!!:) John |
Overhaul OS 1.20
Originally posted by JohnMcGowan here ya go: Send to,: John Sepe 301 Sabal Ridge Circle A, Palm Beach Gardens,Fl 33418 email him at [email protected] He does good work , I just got my saito 91 back from him after both bearings went south. Hope this helps and happy flying!!:) John Thanks, Mike |
Overhaul OS 1.20
do it yourself as it is easy. Get a set of good bearings from Boca bearing and a ring from Frank Bowman and go at it. Take off the head and the pushrods., pull the sleeve and thenb use a toothpick and drive it intothe hole in the back and pull out the wristpin. Take the case and heat it up in the oven and out coems the crank.
Use 1000 grit and sand with oil the inside ot he sleev, make sure the ring rotates freely so that there is no carbon buildup in the groove and re asemble. Make sure the clip is in the piston on the far side and to be safe buy another telflon pad and put it intot he hole that the clip fits in . In this way if the little clip would come loos4e it cannot go anywhere. Put it together in reverse and you have a new engine. |
Overhaul OS 1.20
;) Hey!
Be carefull to note the position of the cam gear/cranksaft if you need to take off the cranck shaft. None of the posts that I have seen on the matter are correct. DON'T RELY ON THEM. Even if they come from OS. No pun intended. |
Overhaul OS 1.20
Thanks everyone.
Scott |
Overhaul OS 1.20
Sorry Mike but I dont have a phone # :(
