RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   OS .45F (https://www.rcuniverse.com/forum/glow-engines-114/10834807-os-45f.html)
NoOneFlysAtMyClub 11-29-2011 12:19 PM
OS .45F
Does anyone know the difference between the OS .45F and the OS .45F-SR?
piper_chuck 11-29-2011 03:52 PM
RE: OS .45F
Couldn't find anything about the .45s, but Iused to have a .25FSR and a .25F ABC. The primary difference between the two was the FSR was ringed.
MetallicaJunkie 11-29-2011 04:22 PM
RE: OS .45F
i have a 60SR and a 61 F-SR and the FSR has a bigger bore carb
maybe its the same thing with the f and the f-sr
rcdude7 11-29-2011 04:32 PM
RE: OS .45F
ORIGINAL: NoOneFlysAtMyClub
Yes, I don't think a .45f exists.
http://www.osengines.com/history/osm...ax-45fsr-h.jpg .45f sr-h
http://www.osengines.com/history/osm...ax-45rsr-m.jpg .45rsr
http://www.osengines.com/history/osm...-max-45fsr.jpg .45f sr
http://www.osengines.com/history/osm...5rsr-m-abc.jpg .45RSR-M ABC
http://www.osengines.com/history/osm...-45fsr-abc.jpg .45f sr ABC
http://www.osengines.com/history/osm...x-46vf-abc.jpg .46vf ABC
http://www.osengines.com/history/osm...46vr-m-abc.jpg .46vr-m-ABC
Does your engine look like any of these?
MetallicaJunkie 11-29-2011 07:25 PM
RE: OS .45F
i have a 45 F-SR the box says 45F-SR abc the engine just has 45-F stamped on it
NoOneFlysAtMyClub 11-30-2011 03:05 AM
RE: OS .45F
Mine has the F stamped on it. I have seen others that have SR stamped on them.
I don't have a box or paperwork for reference.
Maybe BAX will chime in?
vpresley 11-30-2011 07:49 AM
RE: OS .45F
As I remember it, the F version was ABC, the FSR version was not.
Vince
Bax 11-30-2011 08:08 AM
RE: OS .45F
O.S. made a .45 FSR ringed and a .45 FSR ABC. The "SR" meant it was Schneurle ported. The "F" meant it was front intake. O.S. made other engines that were "RSR" or rear intake engines. The rear exhaust versions were the "VF" and "VR" engines.
Usually, the case had a small "SR" just under the exhaust port. Because the center crankcase was identical in the FSR and RSR models, it would not have an "F" or "R" cast into the case.
There was no engine designated just ".45F". The FSR was sometimes written as "F-SR". The O.S. Max .45 FSR came out in 1978:
http://www.osengines.com/history/ostimeline07.html
NoOneFlysAtMyClub 11-30-2011 11:21 AM
RE: OS .45F
Thanks.
downunder 11-30-2011 05:54 PM
RE: OS .45F
ORIGINAL: Bax
Usually, the case had a small ''SR'' just under the exhaust port. Because the center crankcase was identical in the FSR and RSR models, it would not have an ''F'' or ''R'' cast into the case.
Just a minor point there Bax but the original crankcase casting was made for the first Schneurle ported OS which was the pylon/rat racing rear drum valved OS 40SR which probably indicated Schneurle port Rear induction (maybe even Racing). The same crankcase was then used for the Front induction sports engine so the engines were then called FSR although still keeping the SR under the exhaust port. I don't know if the 45FSR kept the SR or whether it was replaced by a 45 under the exhaust.
abacro 12-01-2011 01:21 PM
RE: OS .45F
Bax,your almost completely correct. Only 1 small mishap,that everyone makes. I have the OS complete tare down and manufacturer's labeling for pretty much,every OS engine up to 1991. The Letter's following all the FSR series engines,actually is a acronym for short. The F stands for FOUR,the number of ports in the case. The S is for Schneurle the type of porting. Last but not least is the R,it stands for RINGED only,not rear.
Every FSR engine is a Ringed engine,unless it was modified,which i have seen people do to make the ABC version.
Good lying all Art
downunder 12-01-2011 07:00 PM
RE: OS .45F
ORIGINAL: abacro
Except if it's an ABC like [link=http://www.osengines.com/history/osm640/osm-1980-max-45fsr-abc.jpg]this[/link] one or other FSR's that were ABC/ABN.
Bax 12-02-2011 09:21 AM
RE: OS .45F
Hmmm... The front intake engines all had "F", and the rear intake had "R", as in ".61FSR" and ".61RSR". The front-intake, rear-exhust engine was a "VF", and the rear-intake, rear-exhaust engine was a "VR".
.60 FSR: http://www.osengines.com/history/ostimeline05.html
.60 RSR: http://www.osengines.com/history/ostimeline06.html
.61 VF and VR engines: http://www.osengines.com/history/ostimeline07.html
The airplane VR is here: http://www.osengines.com/history/ostimeline09.html it came out later than the marine versions.
Roary m 12-02-2011 02:43 PM
RE: OS .45F
Incredible, OS had a rotary engine back in 1970.
downunder 12-02-2011 08:50 PM
RE: OS .45F
ORIGINAL: Roary m
There's some history behind this (and I may not have it completely correct because I'm going from memory :)). Graupner in Germany were awarded the license to build small Wankel engines (up to about 100cc IIRC) but didn't have the necessary machinery to make them so asked OS if they would make them. OS didn't have the machinery either but they invested in modern CNC which was the only way to make the epitrochoidal cylinder. The Wankels were sold as Graupner OS (or OS Graupner, whatever :)). The big deal about all this was that OS now had CNC machinery which was perfect for mass producing normal 2 stroke engines (which obviously sell in much larger quantities than the Wankel) so they did a total redesign from anything they'd made before and came up with the 40SR pylon engine which soon morphed into the FSR.
DerFly 10-20-2013 04:15 PM
So, I have just come into ownership of a "45F" (Stamped under exhaust). This is a ringed version; I already have two ABC(N) versions,
I always thought these were fitted with a standard type ring. This one has a Dykes type ring.
Can anyone enlighten me?
DF
