RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Quick question/ need quick answer (https://www.rcuniverse.com/forum/glow-engines-114/108863-quick-question-need-quick-answer.html)
Tyler-RCU 04-18-2002 12:42 AM
Hi folks,
I just dropped my new saito 72 into my H9 Pizazz after removing the TT 46 Pro 2 stroke. I need to know how to turn the throttle arm upside down. The throttle arm is pointing up, but the servo pushrod will be coming from the bottom side.
Thanks for your help.
Tyler
ben flyn 04-18-2002 01:17 AM
There is a allen set screw in throttle arm that will let you rotate it 360 degrees.
Tyler-RCU 04-18-2002 02:01 AM
Thanks Ben
Thanks Ben Fly'n,
I mounted the engine before discovering I needed to rotate the throttle arm. I found the set screw after unistalling the engine again. I appreciate your response.
Tyler
