RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Revive an engine (https://www.rcuniverse.com/forum/glow-engines-114/1093156-revive-engine.html)
deltasoultoad 08-27-2003 01:53 AM
Revive an engine
1 Attachment(s)
Hi folks,
I've been out of the RC hobby for a while, and since I was just a novice then, some help would be welcome. I want to get my old plane flying again. It's a Goldberg Eagle II with an OS 40 engine. I just want to know how to go about getting the engine going again.
Thanks in advance for any help.
Ricky
aka DeltaSoulToad
1Jimbo 08-27-2003 02:00 AM
Revive an engine
Take it completely apart. Look at the bearing and crank to see how bad the rust is. Also check or change all O-Rings. If it looks good just clean it up well and give it a try.
1Jimbo 08-27-2003 02:03 AM
Revive an engine
I forgot, you will probably need to change your fuel tank a lines if they are very old. Or at least make use they are good and clean. Sometimes the tank will get a thick green slime in it after sitting up a long time.
Joatmon 08-27-2003 02:05 AM
Revive an engine
Be like Jimbo, good advice.
Some folks oil it up fairly well before cranking - Marvel Mystery, After run oil, etc. But if its been broken in well in the past, other folks believe your fuel will have enough castor in it to suffice. Your choice here.
deltasoultoad 08-27-2003 02:56 AM
Revive an engine
Hey, thanks for your help!...
keep 'em flying!
