RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   propeller for OS46SF H ringed engine (https://www.rcuniverse.com/forum/glow-engines-114/11004851-propeller-os46sf-h-ringed-engine.html)
kuobin 03-17-2012 06:49 PM
I still have a old but good OS46SF H ringed heli engine ,want use it to flight airplane ,what will be the best propeller to fit?Thanks.
1QwkSport2.5r 03-17-2012 08:54 PM
RE: propeller for OS46SF H ringed engine
ORIGINAL: kuobin
You will probably want to change the cylinder head from the heli type over to the aero type. Also, choose the prop according to the airplane, not the engine. I would think a 9"-11" diameter prop will work just fine but its going to really depend on the plane you're going to put the engine in.
Texastbird 03-18-2012 07:27 AM
I've seen people run a heli engine on a plane in the past. The head didn't seem to present a problem, but around here the temp is in the high 90s quite a bit during the summer, ha, ha. I would think most heli engines are made to rev up, so I would start with a 10X6 on that engine and work from there. Do you have a prop hub to fit that crankshaft?
MrGreenSpeed 03-19-2012 05:53 PM
APC 10.5 X 6 or 10 x 6 or 11.5 x 4
Jeff ;)
BarracudaHockey 03-20-2012 04:40 AM
Why remove the head?
The biggest issue is the short crankshaft on the heli engines.
lfinney 04-02-2012 09:29 PM
the cranks arent much shorter in most cases, the os 46 sf engines love the 11x6 run great, of if you want more speed use a 10x7
jeffie8696 04-02-2012 10:11 PM
The 46SFon my GP Escapade is very happy with a Master Airscrew 11X6 3 series. Very fast combo and Ihave not seen fit to try any others yet.
But I will. http://www.rcuniverse.com/forum/js/f...eeth_smile.gif
