RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   OS 91 Surpass (https://www.rcuniverse.com/forum/glow-engines-114/11050764-os-91-surpass.html)
Guitarman52 04-21-2012 02:30 AM
OS 91 Surpass
Ok all of you engine experts. Need some help. I am getting frustrated with my 91. Seems like we have set the needle valves all over the place. Replaced the glow plug and fuel lines. My engine keeps surging during flight. Also if I cut back the engine too soon on landing it will dead stick. Any suggestions? I never have adjusted the valves, however one of my friends said that would not help my problem. The engine is probably 2 years old now. Help !!!
TomCrump 04-21-2012 02:45 AM
RE: OS 91 Surpass
My 91 Surpass possed a similar problem. I found that the needle valve was moving during flight. I slipped a piece of fuel line over the needle and spring, solving the problem.
GarySS 04-21-2012 08:25 AM
RE: OS 91 Surpass
You might try just giving the carburetor a good cleaning by disassembling and washing all of the parts, etc.
Guitarman52 04-21-2012 09:00 AM
RE: OS 91 Surpass
Both good ideas to try... any others??
Altered1 04-21-2012 04:51 PM
RE: OS 91 Surpass
All the usual suggestions for problem engines....
check for air leaks, tighten up all nuts and bolts, new fuel, clean out carb, set HSN LSN to instruction sheet innitial settings, hotter plug, colder plug, different brand plug etc etc
I'm not sure that checking the valve settings wouldn't atleast allow you to rule them out ?
Be methodical and try one thing at a time....
[edit] sorry - take her out and do all this on a test bench to remove a few variables from the equation....
good luck!
