RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Which is more powerful? (https://www.rcuniverse.com/forum/glow-engines-114/11281210-more-powerful.html)
ScottMcM 10-30-2012 11:52 AM
Between the Saito 300 (twin glow) or the crrc 55cc (twin gas), which is more powerful? I'm guessing the Saito has the edge, since it is 50cc (3.00 cu in =50cc??) and glow is more powerful than gas. I have the saito on a GP Giant Stik, and am considering replacing it with the crrc. But, other than better fuel economy, I think the Saito is the better choice. Am I correct?
NikolayTT 10-30-2012 12:32 PM
RE: Which is more powerful?
Cannot be sure prior finding the right Propellers for each of the motors and for that aircraft aerodynamics...and also keep in mind that in gasoline there is very little added lubricant which is heavy substantial part in the glow motors, so part of the size & weight of the whole construction for the same flight time.... I fly always Glow because they smell better... the rest in the peformance is visible for displacements above 100cc in favor of th gasoline and maybe only because of the weight of the lubrcant.
Hobbsy 10-30-2012 12:34 PM
That would be my choice too, gas engines just don't get it.
flyinwalenda 10-30-2012 12:41 PM
On that plane I would ditch the glow engine in a heartbeat. I've gone gas in all my larger planes and never looked back, The savings in fuel will get you over the minimal difference in torque,
NikolayTT 10-30-2012 12:47 PM
Have you tried the35cc OS-BGX-1 ? Also a converted 80cc Gas into Methanol for Giant Scale : cannot come even near with any Gasoline.
pe reivers 10-30-2012 01:23 PM
A two stroke gas engine with a bit of quality will win over a four stroke glow engine, if both are allowed the same rpm, or use the same prop.
Bog a four stroke down to 6000 rpm, like you can the gas 55, and see what happens! The four stroke glow will shake your plane apart even before it starts detonating, whilst the two stroke gas will purr like a kitten.
blw 10-30-2012 03:07 PM
I prefer the torque of a 4 stroke most of the time. Just my own preferences. Different kinds of engines.
TFF 10-30-2012 04:27 PM
I would pick the Saito as bette and much cooler. 4 stroke glow is about equal to 2 stroke gas except fuel consumption.
SrTelemaster150 10-30-2012 04:55 PM
ORIGINAL: ScottMcM
Put CDI on the 300.
[youtube]http://www.youtube.com/watch?v=vdmLu13UJzs[/youtube]
And another.
[youtube]http://www.youtube.com/watch?v=I9_saL9qVTo[/youtube]
Ray Wasson 10-31-2012 12:36 AM
Has anyone compared torque curves of same displacement 2 & 4 stroke engines?. I think most would be suprised.
NikolayTT 10-31-2012 12:52 AM
In fact the main question is What we are comparing, engines or the Outcome of the 'group' = Engine+#Strockes+FuelWeight+Propeller ... :D
tony0707 10-31-2012 10:19 AM
Fly the plane on both engines and see which performs the best for you
I dislike the gasoline smell in my home
Kit Building and flying mostly 60 and 90 size planes on two cycle glo myself for 23 years
NikolayTT 10-31-2012 10:42 AM
Yes, the pleasure of placing a good looking RC plane in the living room is quite lost if that smells gasoline. Some in Finland use in fact Gasoline where they mix Strowbery kind of odeor in it and then try to immagine to be in Strowberry-field, but that trick works better with Glow-fuels; once we made the whole field smelling like a peach-garden... No kidding, there are people on this Earth who can invent any thing...in the name of RC Planes !
Back to the 'What is more powerful' seems to have simpler answer like 'depends' because after all Power = RPM * Torque and that is different for different RPM for any engine. And there is no much sense to try to use the same propeller for the same engine and different style of flying ... so it looks this question has the simple answer as already pointed by many = depends on what you like and does NOT depend on the motor if the rest of the parameters are not specifed.
Cheers,
Nick
pe reivers 10-31-2012 11:00 AM
If I compare the engine in the video, running a Zinger 22x6 prop at 6800 +-100 rpm with a two stroke MVVS45 (43cc!);
The MVVS running a Bolly 22x8 prop and TD75 canister turns 7350RPM, 5.2hp, 28Lbs thrust (data Greg Gothern)
The Saito 50cc on methanol (glow fuel) running a JZ prop open exhaust at 6900 rpm, 2.95 hp and 19 Lbs thrust
I think I can rest my case here! The smaller gas two stroke engine has almost double the HP  of the larger four stroke on methanol, and 50% more thrust.
ScottMcM 10-31-2012 12:03 PM
Well, I finally made my decision. I installed the 55cc gasser on the Stik, and put the Saito on an old H9 Cap 232, that originally had a Moki 2.10 on it. Not sure if I went up or down on that one[:o] The Moki had loads of power.....but I do love the way the Saito sounds:D Now, what to do with the Moki??
flyinwalenda 10-31-2012 12:38 PM
If the smell of regular pump gas is an issue then go to the nearest airport and get some avgas. About $2.00 more per gallon but there is almost no odor . At least none like pump auto-grade gasoline.
pe reivers 10-31-2012 02:18 PM
My grandson loves the smell of my workshop, which is a mix of gasoline and much more!
BobH 10-31-2012 02:29 PM
Whats your feeling about using CH ignition vs regular glow plugs with regards to power? I have a Saito 300 single carb with a McDaniels onboard glow. I was wondering if I might not get more power switching over to CH...
I have a very old CH single ignition from long time ago. It made a HUGE difference in the way my then OS90 FS ran.
nute12 10-31-2012 04:11 PM
i have a saito 300, and the 450, a 55 cc gas will blow the doors of either. the 450 weighs 7 pounds which makes it almost useless for anything but a warbird or bipe with a real short nose. they are a little better if ya spend the money for 30% nitro content. I just retired my glows, sellin em out.
nute12 10-31-2012 04:14 PM
ORIGINAL: flyinwalenda
some gas stations sell ethanol free gas also... there is hardly any odor.
SrTelemaster150 10-31-2012 04:33 PM
ORIGINAL: nute12
What are you smokin'. [X(]
Gasoline has the oder, not the ethanol.
blw 10-31-2012 07:40 PM
I like the smell of gasoline.
rcguy59 10-31-2012 08:13 PM
Me too. And kerosene is even better.
dadragon 11-01-2012 12:01 AM
Got away from nitro when I got away U control and I dont even remember what year that was it was so long ago.once I went to gas I never looked back.I love the smell weed wackers in the morning.
Rudolph Hart 11-01-2012 01:27 AM
You bin watchin the same movies i have.Is napalm a legal fuel additive??
