need help ID engine
1 Attachment(s)
need help on the ID of this engine.it has a 10 on the otherside.
RE: need help ID engine
That looks like an MVVS...perhaps someone from the MVVS thread will chime in and tell us which one...do you have any more pics? Some showing the entire engine...
Yes, that's an MVVS, and judging from the exhaust it is .21 or larger...
We would be able to tell more if we could see pics of the entire engine and not just the exhaust port. They usually have a number on one side of the engine like 6.5, 3.5, 5.0, 10, 12 things like that. Sometimes a circle where the number was ground off too.
MVVS.
A picture of the other side, and at least a stroke figure should do it. Bore would be nice too, but requires engine dis assembly.<br type="_moz"/> |
Ok that second pic wasn't there when I looked the last time.
The second pic has a 10 number in it. So that makes it a 10cc engine. So it is a 10cc MVVS engine most likely. |
I have one, exactly the same model. It is an early MVVS 10 ccm with the "Modela" logo on the case.
A photo of my ladyfriend holding my example appears in the "Club MVVS" thread. Excellent engine. The hyperlink above takes you straight to the thread and the photo I mentioned. |
Thanks guys for the help
| All times are GMT -8. The time now is 12:09 PM. |
