Webra carb help needed.
1 Attachment(s)
I have a Webra speed 80 and need help with the carb. I did some searching and couldnt find anything on a Webra with a remote needle valve. Do they make one?
RE: Webra carb help needed.
That looks like a "previous owner modification" to me...
You could use just about any manuf. remote needle valve assembly with the way your carb is now... |
There are cheaper RNV's, but I'd highly recommend a Jett Universal RNV. The threads are pretty fine, so small adjustments are easy.
http://www.jettengineering.com/accy/os-dressed.jpg http://www.jettengineering.com/accy/accy.html $25-$35 depending on which one you get. This is of course if you want to use a RNV. If not, you will need to modify the carb thats on it or get a different carb.... |
Remote needle valves, Jett makes them as well as Fox Manufacturing along with a Perry version (from PerryPumps or Conley Precision) and OS engines too. There are some other brands like from ASP, et cetera also.
Yeah that looks like a user modification not something Webra would have done. |
Thanks for the help everyone!
| All times are GMT -8. The time now is 08:14 AM. |
