RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   TT 39 Heli Engine (https://www.rcuniverse.com/forum/glow-engines-114/11505986-tt-39-heli-engine.html)
123Cat 05-09-2013 01:49 AM
TT 39 Heli Engine
Ive been fooling around with this engine a bit
Its done about 2 gallons in a heli
and then about 1 gallon in a plane
and I put it back in a heli with the aeroplane head
and its not tuning all that good getting a little lean
Im getting a heli head ,
Looking at the cylinder wear
the ring is not touching the top of the bore in a couple of spots ,
that cylinder is not all that round
so its not really the head that is sending it lean
its the really non existant compression
What can I do
<br type="_moz" />
BarracudaHockey 05-09-2013 03:43 AM
RE: TT 39 Heli Engine
Not to sound flippant, but throw it away and get an OS37
aspeed 05-09-2013 04:13 AM
Ring and/or cyl?  I would try adding more castor in the fuel just to seal a bit better. It is cheaper and easier than a new ring. (no I am not one of those castor fans, more of any synthetic oil may work too)
123Cat 05-09-2013 02:00 PM
Ive got 20% castor in now , Its not tuning bad considering the lack of compression Im tempted to just run it to round up the cyl
Its not cutting out
Maybe its like an Enya and needs heaps of running to run it in
That cylinder is so out of round its remarkable
what are TT doing ????
1QwkSport2.5r 05-09-2013 02:17 PM
Your factory piston ring might just suck and should be replaced with a Frank Bowman ring. Not all rings are created equal. Some imported rings take forever and eternity to break in and seat, if they ever do. Maybe TT used a crappy ring in that engine?
Did you get it used or NIB?
Also, could you post a picture of the inside of the liner where you say it's out of round?
bigedmustafa 05-09-2013 02:49 PM
ORIGINAL: 123Cat
Its not cutting out
That particular model of helicopter engine, unlike most of Thunder Tiger's otherwise excellent products, isn't normally held in high regard by most helicopter pilots. Maybe a new ring or flying it more will improve it, but you might be time and fuel ahead to just replace it.
MECOA and ASP both offer .46 heli engines for under $100, so I don't know that I'd be all that willing to spend a lot of time messing around with a TT .39 that has a weirdly shaped cylinder. Good luck and good shopping!
123Cat 05-09-2013 03:39 PM
I will fly it a bit more and report,
I have never heard of one peeling the nickel ,
so I think Im safe there
its got new bearings in about 8 flights ago
Will give it another gallon that should build up a bit more compression
123Cat 05-10-2013 02:23 AM
One good thing about the TT is that the starter turns over very fast, and parts are cheap , Ive done a lot of work on the carbarooster, and other secret mods , to get to get it
to motivate so I dont want to waste that , and I have a large volume muffler coming
that Im making
so if the ring can round up all be very good
123Cat 05-11-2013 06:41 PM
Put a couple more tanks thru usual heli problems balance and close calls
Its quite powerful
and holds its tune well,
Ive done a lot of work with the idle needle as it affect up to 80% of the range
still can turn it over prop nut style with thumb and little finger,
you dont really need compression <br type="_moz" />
