Marvel Mystery Oil?
I used to use Marvel Mystery Oil(for air tools) as a after-run oil.....is it really OK t use now days?
Dave |
RE: Marvel Mystery Oil?
I've used it for years...........is there a problem now????????
I haven't heard of them changing the formulation. The air tool oil is what you want - to prevent rust. I follow Clarence Lee's recipe, a 50/50 mixture of MMO air tool oil and ATF.
Just my $.02 Bob |
This guy at an LHS told me not to use marvel mystery oil in my engines as this will glue the piston to the sleeve. It turns out that this guy and his dad created an after run oil and that they are still getting paid for it. I used to use a 50 50 mix of atf and mm and this worked great but someone told me to use the MM Airtool oil which I use now. The only thing I've noticed is when you start your engine for first time it smokes allot. Michael
MM, air tool oil, any non detergent 10w works fine. Clarence Lee has stated "if you want to stop corrosion, take out the glow plug and submerse the engine in oil." He went on to state that being his earlier remark was not practical, he suggested what I did in my opening response.
Gary, aka Red Baron Gary |
I use Remington gun oil. Never had a problem. It works well on my guns too! ;)
Max |
just make sure to use the Air Tool oil - the other "marvel mystery oil" isn't what you want to use.
Dub Jett recommended using the Marvel air tool oil to me as an after run oil. I figure if it's good enough for him, it's good enough for me. |
Been using Marvel Air Tool Oil for over 30 years with wonderful results. I do mix it with transmission fluid for long storage as I have a few more engines than I do airplanes.
ORIGINAL: mkjohnston This guy at an LHS told me not to use marvel mystery oil in my engines as this will glue the piston to the sleeve. It turns out that this guy and his dad created an after run oil and that they are still getting paid for it. I used to use a 50 50 mix of atf and mm and this worked great but someone told me to use the MM Airtool oil which I use now. The only thing I've noticed is when you start your engine for first time it smokes allot. Michael Not particularly easy to find, though. Compressor oil is, but I've been told it's not the same thing as air tool oil. Surely other people make air tool oil, not just Marvel? Iskandar |
ORIGINAL: Red Baron Gary MM, air tool oil, any non detergent 10w works fine. Clarence Lee has stated ''if you want to stop corrosion, take out the glow plug and submerse the engine in oil.'' He went on to state that being his earlier remark was not practical, he suggested what I did in my opening response. Gary, aka Red Baron Gary Iskandar |
I found the air tool at an a local auto parts store and it comes in a small bottle with a flip top. It works pretty good too!! Mj
Is the Marvel Air tool oil really that much better than ATF by itself?
Advance Auto Parts has MMOil-air tool oil in the small bottles
Same experience, the stuff turned into red scabs.
ok. Since WD-40 stands for water dispersant # 40 and was invented to prevent corrosion on Nuculerhttp://www.rcuniverse.com/forum/js/f...sn/biggrin.gifmissles would it not work in our engines? You can buy it in a non aerosol can and pour it right in. It is the same thingas air tool oil and I have used itin my nail guns for years.
ORIGINAL: raptureboy ok. Since WD-40 stands for water dispersant # 40 and was invented to prevent corrosion on Nuculerhttp://www.rcuniverse.com/forum/js/f...sn/biggrin.gifmissles would it not work in our engines? You can buy it in a non aerosol can and pour it right in. It is the same thingas air tool oil and I have used itin my nail guns for years. Same as MMO, its just a cheap oil thined with mineral spirits. When the mineral spirits evaporats you have a very sticky oil that hardens. Makes a very good glue. |
I used to say that I kept WD40 in a separate room from my engines. I have since gotten rid of it. NAPA Fogging Oil makes a great ARO and a $3.00 can lasts a long time.
Don't use in YS engines
Found Marvel Air Tool Oil in small bottle with flip top at Menard's.
So what exactly is the mystery behind this oil anyway[&:]
I can't tell you that Marvel Mystery oil is good or bad to use as after run. The one thing I can tell you is that my first and last experience with this product was about 10 years ago when I thought I was doing A good thing with A OS108 motor that I wasn't going to use for a while. I fully lubricated the intake and exhaust ports with the Marvel oil, then put it in a plastic vacuum sealed bag. A year later when I opened the seal to use the motor I found a rusted solid frozen piston, the engine was completely seized up and useless. For what it's worth. jmpups
ORIGINAL: jmpups I can't tell you that Marvel Mystery oil is good or bad to use as after run. The one thing I can tell you is that my first and last experience with this product was about 10 years ago when I thought I was doing A good thing with A OS108 motor that I wasn't going to use for a while. I fully lubricated the intake and exhaust ports with the Marvel oil, then put it in a plastic vacuum sealed bag. A year later when I opened the seal to use the motor I found a rusted solid frozen piston, the engine was completely seized up and useless. For what it's worth. jmpups I suggest venting the crankcase of 2-strokes for a few days (piston at BDC) before loading with oil. This is my practice, though I use 5% nitro in all of my engines except one. I rarely use anything for storage in the 2-strokes as the castor does a good job of keeping stuff rust free. My Enya 60-4C got filled and stored full of ATF for the winter. Turns smooth as butter |
Marvel Air Tool Oil user here as well in all engines glow and gas.
: popcorn: |
Hi All, I put in Marvel Mystery Oil in my OS .40FP 28 years ago and now that I'm getting back into the hobby, I pulled it out and unwrapped it....... turns smooth and no visible residue.</p> Works for me!!</p> |
